Author Topic: HDTV Question  (Read 3572 times)
mcdo15
  • Last login:February 16, 2008, 01:49:17 pm
  • why can't i make up my mind
HDTV Question
« on: August 17, 2005, 09:44:37 pm »
Hello...im intrested in buying a hdtv projecter....   seeing that the projector has only 1 output for hd, how do i hook up mutliple devices at one time....   say xbox360, hd cable box, etc...  do they make a/v recievers cable of handleing hd?   im a noob still with hd still don't yell at me...
NY_in_TX
  • Last login:February 25, 2017, 11:19:54 am
  • First play's free...next one will cost ya
Re: HDTV Question
« Reply #1 on: August 17, 2005, 11:09:53 pm »
I'm assuming you mean "one input for HD"
is it DVI or component?
best way for component (and the way I do it)  is to get a an AV receiver with  component switching.  you run everything through the receiver audio and video.  most decent ones will have this.
DVI I'm not sure (don't use it for HD...old box)
mcdo15
Re: HDTV Question
« Reply #2 on: August 18, 2005, 06:05:39 am »
thanks..i meant input..
it has 1 component, and 1 dvi.  this hdtv crap is getting more expensive if i need to buy a receiver...huh
TOK
  • The Game Always Wins
Re: HDTV Question
« Reply #3 on: August 19, 2005, 06:38:31 am »
Since you have DVI and Component, you can put the XBox on one and the HD cable box on the other. That's going to leave you with the compromise of using S-Video if you're hooking up a DVD player, but image quality won't suffer much since they're only 480P anyway.
Santoro
  • Santoro
  • Trade Count: (+32)
  • Boycott Quarters!!!
    • ArcadeReplay!
Re: HDTV Question
« Reply #4 on: August 19, 2005, 07:46:32 am »
In the past I have successfully switched component HD/DVD video with one of those cheapie rat shack AV swichers.  You just hook up the 3 RCA component jacks ignoring the audio-video labels on the switch.
http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&product%5Fid=15-1983
Certainly not a videophile solution but it actually works.  You just lose the ability to switch sources from the couch.  bummer. ;)
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
Re: HDTV Question
« Reply #5 on: August 19, 2005, 02:52:27 pm »
that's a neat hack santaro... there are modest component cable switchers out there (even saw one at walmart!)  some even are Ir controlled so you could hypothetically get your universal remote to handle the switching chores...
*shrug*
rampy
JackTucky
  • Last login:January 04, 2021, 12:00:58 pm
  • Soon I will post that I am a triathalete
Re: HDTV Question
« Reply #6 on: August 19, 2005, 03:38:28 pm »
rampy
I'm pretty sure if you spend a few $ more, you'll get one that will switch to whichever source is active, so no manual switching necessary.
Art
Well, that's where we go a-ridin' into town, a whampin' and whompin' every livin' thing that moves within an inch of its life. Except the women folks, of course.
Santoro
  • Santoro
    • ArcadeReplay!
Re: HDTV Question
« Reply #7 on: August 20, 2005, 11:06:08 am »
The cheapest one of those was ~70$us if I recall...  I was just buying time until I got my component-switching reciever.  Good for those on a strict budget.
Then again "HDTV owner on a strict budget" is sort of an oxymorn....
MnMCaputo
  • Last login:January 10, 2014, 05:31:40 pm
  • Built original Monster Arcade
Re: HDTV Question
« Reply #8 on: August 23, 2005, 07:59:34 am »
This should work great, its a little pricey but you wont have to get up to manually switch
http://www.copperbox.com/lite/popinfo.php?lc_code=1154A&uneek=54552276
Built Monster Arcade, Steampunk MP3 touchscreen jukebox, NES itx conversion
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
Re: HDTV Question
« Reply #9 on: August 23, 2005, 08:31:23 am »
Save your money and buy a mid-range receiver. The newer ones are pretty good and they cost about twice as much as that switch. I'm looking at buying a Sony STR-DE998, since it's got component up-conversion (it'll take your component, s-video and composite connections and output them all through one component output). You should be able to pick one up for around $350.
The DE998 only has two component inputs, but then my current receiver doesn't even have s-video  :'(
Edit: Scratch that Sony. The Denon 1705 has more component inputs, is cheaper and the reviews sound great
« Last Edit: August 23, 2005, 08:51:08 am by JoyMonkey »
Re: HDTV Question
« Reply #10 on: August 23, 2005, 09:22:44 am »
Of course, none of which applies to a person with Satellite.  We would need an entirely different set of receivers.
JoyMonkey
    • JoyMonkey.com
Re: HDTV Question
« Reply #11 on: August 23, 2005, 09:26:45 am »
I'm not familiar with modern satellite systems. What kind of output does your satellite box have? DVI?
Re: HDTV Question
« Reply #12 on: August 23, 2005, 09:29:51 am »
S video at the highest, but it's not HD.  The difference would be that your satellite receiver would have to have the HD decoder built into the receiver, because it would have to decode the proprietary satellite signal into HD and then output it to the TV.
JoyMonkey
    • JoyMonkey.com
Re: HDTV Question
« Reply #13 on: August 23, 2005, 09:34:57 am »
Well yeah, same goes for digital cable receivers too. Thats why the surround sound receivers (like those I mentioned above) have inputs marked 'TV' for your satellite/cable receiver.
Re: HDTV Question
« Reply #14 on: August 23, 2005, 09:42:15 am »
So you're saying that there is a specific HD receiver for every cable provider?  I guess that could make sense, but would you need a second one for OTA?
I actually use the CD input for satellite because the TV input doesn't have a digital input, only RCA.  My Dtivo outputs optical, which goes into CD on the receiver.  My receiver does a great job but it's far from high end.
JoyMonkey
    • JoyMonkey.com
Re: HDTV Question
« Reply #15 on: August 23, 2005, 09:48:41 am »
AFAIK the only way of picking up OTA HD channels is to plug an antenna into a HDTV that supports OTA. I think it's a TV specific thing.
Edit: but then again, I don't have a HDTV and could well be talking through my arse.
« Last Edit: August 23, 2005, 09:50:15 am by JoyMonkey »
Re: HDTV Question
« Reply #16 on: August 23, 2005, 09:55:59 am »
No, it still requires an HD decoder, unless your TV had a decoder built in.  Many HDTVs do not have a native decoder in them.  I think many cable or Satellite decoders will do it for you, though, with an extra input you would connect to an antenna.
JoyMonkey
    • JoyMonkey.com
Re: HDTV Question
« Reply #17 on: August 23, 2005, 10:18:54 am »
Stepping back a few posts and going back to plain-old switches, if you don't want to splash out on a new receiver straight away, here's another alternative:
http://store.videogamecentral.com/pesyseprocwa.html
This will switch a bunch of component inputs and even digital optical inputs for $80. There's also a much cheaper one available ($30) that doesn't handle digital sound.
zaphod
  • Last login:September 04, 2012, 11:11:38 am
    • ArcadeCab.com
Re: HDTV Question
« Reply #18 on: August 23, 2005, 10:23:39 am »
Great site with loads of information related to your questions: http://www.avsforum.com/avs-vb/
Re: HDTV Question
« Reply #19 on: August 23, 2005, 10:28:16 am »
I have that Pelican switcher.  I use it for:
DVD
VCR
DirecTivo
N64
Dreamcast
Flawless on all of them.  There's one other game system I can't remember at the moment, too.  It even has one front input for temporary items like a video camera.  All inputs have up to Svideo, and either two or three inputs have component video and optical audio.  You will NOT get a better switcher at a better price.  It's a STEAL at $80.
pointdablame
Re: HDTV Question
« Reply #20 on: August 23, 2005, 11:54:25 am »
DVD
VCR
DirecTivo
N64
Dreamcast
I've seen that switcher a few times now and hesitated on getting it.  It may just be worth it though I think.  My only problem is I don't have an HDTV, so the component inputs won't do as much good as it could, but oh well.... it's still better than composite or Svid
first off your and idiot
Re: HDTV Question
« Reply #21 on: August 23, 2005, 11:58:06 am »
DVD players use component.  Mine does.
pointdablame
Re: HDTV Question
« Reply #22 on: August 23, 2005, 12:08:22 pm »
I meant that component won't be as nice if it's not feeding into a hi-def display.  I have 5 things in my bedroom that use component right now, and its a BETTER picture, but it would look nicer fed into an HDTV, which I don't have.
Re: HDTV Question
« Reply #23 on: August 24, 2005, 01:55:27 pm »
