Author Topic: SK Juke question  (Read 1667 times)
kenmelk
  • Last login:February 08, 2008, 09:39:13 am
  • We live "In a world of PURE imagination"
SK Juke question
« on: August 15, 2005, 02:04:44 am »
i have a question.  I am running MAME 99 and Mamewah (newest release), and i was wondering if there is a way for me to "launch" the SKJUKE via my MAMEWAH Frontend?  Or do i have to shutdown MAME and MAMEWAH then run the juke?  Also i would like the info on how to run it through MAMEWAH as i want to do this.
Thanks,
Ken
GALAGA...a way of life!
whatisk
  • Last login:March 27, 2017, 06:41:39 am
  • Nothing to see here
Re: SK Juke question
« Reply #1 on: August 15, 2005, 07:05:05 pm »
It can be done (as I have it as an option in Mamewah).
If you follow this method, you could run any program from within Mamewah.
You need to create a shortcut to the exe file and put it in a folder (I have a folder for storing all the shortcuts I want).
You then create a new emulator ini for them and have the rom folder as the folder where the shortcuts are stored and the rom extension as 'lnk' (for winXP).
I can post my ini file when I get home from work as an example, otherwise I'm sure there are other threads around that would no doubt explain a bit better than I have.
No trees were harmed in the creation of this post. Though several electrons were severely inconvenienced.
mumbles
  • Last login:January 25, 2024, 09:20:01 pm
« Reply #2 on: August 15, 2005, 09:16:06 pm »
I would like to be able to have sk jukebox set up as an emulator in mamewah too to make things easier. I tried doing as you suggested above but it just won't load. can ou post or email your ini file please??
Also does anyone have a nice jukebox layout to use in mamewah with this??
whatisk
« Reply #3 on: August 15, 2005, 10:22:39 pm »
Will definitely post my ini file when  get a chance (probably not until Wednesday as my PC is at my parents where I'm building my cab).
I am using a fairly bland layout for it as on the same screen I also have other apps that I can choose (PC games). If you created a nice jukebox layout, all that would be listed on there is an option to load up SKJ.
whatisk
« Reply #4 on: August 16, 2005, 07:12:17 pm »
Okay, here it is...
### z_otherapps.ini (mamewah v1.61) ###
emulator_title                            Jukebox & Other Programs
### List Generation Settings ###
rom_path                                  c:\links
rom_extension                             lnk
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder
### Execution Settings ###
emulator_executable                       PC
commandline_format                        "[rompath]\[name].[romext]"{nodosbox}{nosafelaunch}{cursor}
alt_commandline_format_1                  [name]
alt_commandline_format_2                  [name]
game_specific_config_path
### Artwork Locations ###
artwork_1_image_path                      c:\links
artwork_2_image_path
artwork_3_image_path
artwork_4_image_path
artwork_5_image_path
artwork_6_image_path
artwork_7_image_path
artwork_8_image_path
artwork_9_image_path
artwork_10_image_path
movie_preview_path
movie_artwork_no                          1
### Screen-Saver Settings ###
enable_music_in_screensaver               0
saver_type                                slideshow
movie_path
movie_fullscreen                          1
quit_delay                                30
wrapper_executable
wrapper_commandline_format                [name]
scr_file
### External Application Settings ###
ipc_file_or_path
app_1_executable
app_1_commandline_format
app_2_executable
app_2_commandline_format
app_3_executable
app_3_commandline_format
auto_launch_apps
### Additional Settings ###
music_path
lcd_display_file_path
lcd_fe_text
### Settings used by MAMEWAH ###
current_list                              0
mumbles
« Reply #5 on: August 16, 2005, 10:59:06 pm »
thanks for that. I've got it all up and running no worries now. I just have to find a nice jukebox skin now!!!
