Author Topic: NEO GEO 2 slot possibilty  (Read 2258 times)
tommy
« on: August 15, 2005, 01:09:45 am »
Is it possible to take a Neo Geo 1 slot PCB and with the cartridge connector from another one slot... wire it up as a 2 slot PCB?
I doubt it but figured i would run it by you guys.  8)
Stingray
Re: NEO GEO 2 slot possibilty
« Reply #1 on: August 15, 2005, 08:34:10 am »
I don't think I understand what you want to do. If you want to take a cart connector from a one slot board and add it to another one slot board and make a two slot board, I can't imagien how that would work. Where are you going to solder the second slot?
-S
ClubNinja
  • Last login:October 19, 2010, 12:46:02 pm
  • Comfortably Numb
« Reply #2 on: August 15, 2005, 08:45:15 am »
tommy
« Reply #3 on: August 15, 2005, 04:04:35 pm »
I would fabricate some kind of holder to keep everything in place
A miracle of engineering would do it. That said, I suspect you'd be better off buying a 2 slot PCB.
Would the board recognize that there are 2 carts pluged in and would they both switch to one another with a button press?
It just seems much less expensive then buying a 2 slot when i have everything i need already, but do i want to risk ruing 1 or even 2 of my boards.
« Reply #4 on: August 15, 2005, 04:09:53 pm »
The miracle would be designing a circuit that handled the switching between cart slots, getting it properly soldered into the appropriate traces, and then doing it in a way that doesn't break if you breathe on it.
Spend the extra small bit of cash and buy a 2 slot.  The way you want to do it would cost an experienced EE guy dozens of hours.
Stingray
« Reply #5 on: August 16, 2005, 08:18:24 am »
That's not what I meant. You could keep everything in place with a bag of cement if it came to that. I meant where are you going to solder the cart slot to the board. It's not like there's an extra unused cart footprint on the board.
-S
« Reply #6 on: August 16, 2005, 10:42:33 am »
Or a controller circuit for switching between cart slots.
