Author Topic: PINMAME Question  (Read 2116 times)
kenmelk
  • Last login:February 08, 2008, 09:39:13 am
  • We live "In a world of PURE imagination"
PINMAME Question
« on: August 15, 2005, 12:22:45 am »
Please forgive me if this question is not acceptable here.
I want to know where i can get pinball roms for PINMAME?
I can find "tables" for pins, but i do not think that is what i want.  I would like to add PINMAME to my cab for some other kind of fun, Please help me out here.
Also can i "bring up" PINMAME with my MameWah?  Like have my MAMEWAH running, with my mame games and lists, then "switch" to the PINMAME in MAMEWAH some how?  If that is possible, PLEASE help me set that up!
If anyone knows of a pinball rom burner, I will be happy to purchase the PINBALL ROM burning service from them.
Thanks in advance for any help.
GALAGA...a way of life!
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
Re: PINMAME Question
« Reply #1 on: August 15, 2005, 12:45:18 am »
Yes you can set up pinmame to run from mamewah, see below.  As to your first question, this is not the place to ask such shady things  :o.  You may want to search for the two popular pinmame sites, as these should help you get the thing running completely ;).
kenmelk
« Reply #2 on: August 15, 2005, 02:03:10 am »
I so not know what i am supposed to "see below".  I appreciate the info on the mamewah thing, but i still need to know how to run it through mamewah.
Thanks,
Ken
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #3 on: August 15, 2005, 02:22:52 am »
I have done some research, and I hope this helps noobs around the world.
 If you know how to set up vpinball and pinmame, you then need to get a wrapper from howard casto's lazarus site.  Follow what the instructions that come with it say to do.  (Put the wrapper in your tables folder)  Then setup your mamewah paths with the .ini the way whatisk has his set.  I am assuming you know enough about mamewah to get to this point and have a layout installed from http://www.screenshotarchive.com/  or some other vpinball layout.
Here are some helpful sites.
All the vpinball you can handle:
http://irpinball.ztnet.com/
http://www.vpforums.com/
Howard Casto's Lazarus page that has the wrapper for vpinball:
http://www.oscarcontrols.com/lazarus/wrapperdownload.html
The official board for mamewah questions:
http://www.mameworld.info/ubbthreads/postlist.php?Cat=&Board=arcadeospc2jamma
Here is a very good tutorial on setting up mamewah and explanation of it:
http://forum.arcadecontrols.com/index.php?topic=41322.msg376513#msg376513
Here is whatisk's .ini from the thread:
### x_vpinball.ini (mamewah v1.61) ###
emulator_title                            Visual Pinball
### List Generation Settings ###
rom_path                                  C:\Pinball\tables
rom_extension                             vpt
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder
### Execution Settings ###
emulator_executable                       C:\Pinball\tables\vp-launch4.exe
commandline_format                        [name]{nodosbox}{nosafelaunch}{cursor}
alt_commandline_format_1                  [name]
alt_commandline_format_2                  [name]
game_specific_config_path
### Artwork Locations ###
artwork_1_image_path                      c:\pinballscreen
artwork_2_image_path                      c:\pinballflyers
artwork_3_image_path
artwork_4_image_path
artwork_5_image_path
artwork_6_image_path
artwork_7_image_path
artwork_8_image_path
artwork_9_image_path
artwork_10_image_path
movie_preview_path
movie_artwork_no                          1
### Screen-Saver Settings ###
enable_music_in_screensaver               0
saver_type                                slideshow
movie_path
movie_fullscreen                          1
quit_delay                                30
wrapper_executable
wrapper_commandline_format                [name]
scr_file
### External Application Settings ###
ipc_file_or_path
app_1_executable
app_1_commandline_format
app_2_executable
app_2_commandline_format
app_3_executable
app_3_commandline_format
auto_launch_apps
### Additional Settings ###
music_path
lcd_display_file_path
lcd_fe_text
### Settings used by MAMEWAH ###
current_list                              0
In closing, if you search these boards, you will find many ways this has been set up in mamewah, as JCrouse has a wrapper as well.  I would stick with the method here, as it is the first one that has worked very well.  Howard's wrapper works perfectly.(Except for that damn stay off drugs thing in the beginning-  ;D)
« Last Edit: August 15, 2005, 02:53:22 am by mccoy178 »
Tiger-Heli
    • Tiger-Heli
« Reply #4 on: August 15, 2005, 07:22:38 am »
Excellent summary!
