Author Topic: Mala?  (Read 7882 times)
StatusQuo
  • Last login:December 26, 2019, 03:16:54 pm
Mala?
« on: August 14, 2005, 10:56:48 pm »
Well I finally have my cabinet up and running. I've been trying to set up front-ends and havn't had any luck. Which is ironic because I didn't have any trouble setting them up when I just had them on my PC with gamepads... Don't ask me why.
Anyways Mala seems really cool and so I tried it. I got it to read my gamelist and all that stuff. But when I load it, it just sits there on the loading screen and does nothing. None of the pictures or marqee's show up either. I know what your thinking...check the path. Well I did and they are correct. If you guys have any idea's I'd really appreciate it.
Hoopz
  • Intellivision Rocks!
Re: Mala?
« Reply #1 on: August 14, 2005, 11:09:11 pm »
Can you post your mala.ini file?
loadman
  • Moderator
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
Re: Mala?
« Reply #2 on: August 14, 2005, 11:16:05 pm »
How Bizarre,
It any case make sure in settings that you have your 'Mame Window State' set to normal until your problem is fixed.
That way you should see any Mame errors that may occur when you launch a game
StatusQuo
Re: Mala?
« Reply #3 on: August 15, 2005, 01:19:18 am »
Here's my ini
[Mala]
FirstTimeRun=0
[JukeBox]
Title=Jukebox
BaseDir=C:\Program Files\MaLa\
Mode=0
[Joystick]
UseJoystick=0
CentXMin=1
CentXMax=2
maxJoyvalX=65535
CentYMin=1
CentYMax=2
maxJoyValY=65535
Repeat=125
1Up=1
1Down=2
10Up=0
10Down=0
StartGame=12
SwitchOrientation=0
FlipOrientation=0
Exit=0
MenuOpenClose=0
MenuUp=0
MenuDown=0
MenuSelect=0
AddGameToList=0
RemoveGameFromList=0
PreviousList=9
NextList=14
PreviousEmulator=0
NextEmulator=0
[Emulator]
Typ=0
Selected=0
[Mame]
Title=M.A.M.E. v0.98 (Jul 10 2005)
NamingDefinable1=0
NamingDefinable2=0
NamingDefinable3=0
NamingDefinable4=0
WindowState=1
AutoRotate=0
AutoRotateMaLa=0
Exe=D:\mame\mame32.exe
Snaps=D:\mame\snap
Marquee=D:\mame\artwork
CPanel=D:\mame\cpanel
Definable1=
Definable2=
Definable3=
Definable4=
Video=
InfoFile=D:\mame\mame.xml
Roms1=D:\mame\roms
Roms2=
Roms3=
CatverFile=D:\mame\catver.ini
NplayersFile=
ControlsFile=D:\mame\mame.ini
[GameList]
SelectedGameList=allgames
Filter1Typ=0
Filter1=off
Filter2Typ=1
Filter2=off
Filter3Typ=2
Filter3=off
Filter4Typ=3
Filter4=off
Having=0
Working=0
Master=0
Excludes=
[Layout]
SelectedLayout=standard
SwitchWithEmulator=0
SwitchWithGamelist=0
UseRelativLayoutPath=1
UseLayoutNameAsDir=0
LayoutDirectory=
[GUI]
Vertical=0
Flip=0
OrientationFilter=0
ShowSnap=1
ShowVideo=0
KeyRepeat=25
HideMouse=1
SmallMenu=0
KeepAspectRatio=1
RotateGameLists=0
UseScrollDelay=1
ScrollDelay=50
UseScrollExceptionText=1
UseScrollExceptionHardware=0
UseScrollExceptionSound=0
PictureQuality=1
GameListSortField=0
SelectedGame=405
[Ctrl]
1Up=38
1Down=40
10Up=37
10Down=39
StartGame=13
SwitchOrientation=32
FlipOrientation=288
Exit=27
MenuOpenClose=53
MenuUp=38
MenuDown=40
MenuSelect=13
AddGameToList=187
RemoveGameFromList=189
PreviousList=33
NextList=34
PreviousEmulator=36
NextEmulator=35
SteadyKey=16
UpInterval=10
DownInterval=10
UseDefaultAsFlipped=1
[Flipped]
1Up=38
1Down=40
10Up=37
10Down=39
StartGame=13
FlipOrientation=288
Exit=27
MenuOpenClose=53
MenuUp=38
MenuDown=40
MenuSelect=13
AddGameToList=187
PreviousList=33
NextList=34
PreviousEmulator=36
NextEmulator=35
SteadyKey=16
[Sounds]
Enabled=0
UseSoundsFromLayout=0
Movement=
StartGame=
EndReached=
ListSwitch=
MenuSelect=
Exit=
[BGMusic]
Status=1001
Volume=80
LastSong=0
LastSongPos=0
PauseOnGameStart=1
UseFades=1
FadeInterval=30
Shuffle=0
Repeat=0
[AutoGameList]
Enabled=0
Max=10
Interval=0
Timestamp=8/10/2005 9:19:59 PM
[Hardware]
UseLCD=0
UseLED=0
[LCD]
Rows=2
Cols=16
[LED]
OffWhileGaming=0
CatchMameLedState=0
[AttractMode]
UseAttractMode=0
Interval=30000
swindus
  • Last login:July 28, 2021, 05:52:50 am
    • MaLa - M.A.M.E. Launcher
Re: Mala?
« Reply #4 on: August 15, 2005, 02:12:09 am »
[Layout]
The standard layout displays no images. Edit with the layout editor or download another one from the mala homepage.
