Author Topic: Perspex for screen?  (Read 5394 times)
DannyH
  • Last login:August 17, 2009, 07:27:28 am
Perspex for screen?
« on: August 14, 2005, 07:57:56 pm »
Hi,
I have been debating whether I should use glass or perspex to put over the screen, I have pretty much concluded perspex because I can customize the size where I need to.
However Now I need to know what thickness. Will 3mm be thick enough or should I go thicker. Should I also go for a clear screen or tinted?
any suggestions would be much appreciated
Bones
  • [Moderator]
Re: Perspex for screen?
« Reply #1 on: August 14, 2005, 08:17:50 pm »
I have found perspex / Lexan is easily marked. I just installed 8mm Lexan for my screen and it looks OK but the act of putting it in & out while adjusting things has left some minor marks. These may buff out, I haven't tried yet.
I have sent out some emails asking about local availability of tinted safety glass and will feed this info back to you. Looking at the pics on this board, the tinted glass looks really good and helps hide the insides of your cabinet.
Alternatively, let me know roughly what size screen you are after. I have a fair bit of this 8mm Lexan leftover and you can have it if you want. I don't know how you would go about tinting it though.
DannyH
« Reply #2 on: August 14, 2005, 08:24:59 pm »
I am looking for roughly 600mm x 500mm. let us know.
I am not concerned about a few minor marks and was thinking about an ultra clear contact as a protection for the screen.
let us know also, let me know the prices you get for the other stuff around Sydney I would be interested in that as well
Bones
  • [Moderator]
« Reply #3 on: August 14, 2005, 08:30:50 pm »
I am almost 100% positive I have an offcut that can make that size. I will check tonight and let you know.
DannyH
« Reply #4 on: August 14, 2005, 08:38:27 pm »
dude your an absolute champion!
Any size around that should be alright as well!
Bones
  • [Moderator]
« Reply #5 on: August 14, 2005, 08:51:25 pm »
My pleasure. It is destined for the trash can anyway, might as well go to a good home.
whatisk
  • Last login:March 27, 2017, 06:41:39 am
  • Nothing to see here
« Reply #6 on: August 14, 2005, 09:48:59 pm »
Hi,
I have been debating whether I should use glass or perspex to put over the screen.
I too am at the stage of looking at putting a screen over my monitor (definitely tinted) and have been trying to decide whether to go for glass or perspex.
Is anyone able to give some feedback as to how each looks, etc?
No trees were harmed in the creation of this post. Though several electrons were severely inconvenienced.
DannyH
« Reply #7 on: August 14, 2005, 09:56:40 pm »
If you know the exact size you want I would go Glass, probably slightly cheaper and much more scratch resistent.
Perspex scratches very very easily
whatisk
« Reply #8 on: August 14, 2005, 10:59:22 pm »
Thanks. Definitely know the size needed.
danny_galaga
  • Last login:Today at 06:40:20 am
    • dans cocktail lounge
« Reply #9 on: August 15, 2005, 02:20:09 am »
a lesson in leaving the protective film on until AFTER you're done  ;)
Bones
  • [Moderator]
« Reply #10 on: August 15, 2005, 02:23:37 am »
Yeah but I was going to paint a black border and then changed my mind.  :P
Bones
  • [Moderator]
« Reply #11 on: August 15, 2005, 02:59:03 am »
I really didn't need to quote that, I just like the way it sounds.....
OK DannyH,
I have two offcuts you can have. Both 8mm in thickness
1 piece is 500mm x 770mm. This piece still has most of its protective film left on, but I did discard this piece when cutting my own so at the time I considered it the worst half of the original sheet I started with.
1 piece is 690 x 575. This piece was cut for my own screen (I ordered some tinted glass today). This piece is pretty good. It has a couple of minor marks and has some MDF dust on it, but really it is fine.
PM me for details if you want one or both.
As for the tinted glass details, I will update Project bones with some pictures later in the week when I pick the glass up, hopefully by Friday.
« Last Edit: August 15, 2005, 04:32:56 am by BrokenBones1 »
« Reply #12 on: August 15, 2005, 05:55:03 am »
IMO glass is better.  It doesn't scratch easily, looks good and doesn't flex.  I used tinted glass for my cabinet and it looks great.  The only downside is that most people would need a glass shop to cut it to size, whereas perspex you can cut yourself...
Franco
« Reply #13 on: August 15, 2005, 09:48:02 am »
I went down the perspex route on mine as i figured it would be cheaper. A while after installing the perspex when I had some spare cash I thought I would get a price for some cut glass and It turned out that the safety glass was cheaper! I would go for the glass if I were you. Like its been said it is more scratch resistant, easier to clean and IMO stronger. I picked my perspex up slightly dodgily one day and it cracked.
PetitMorte
  • Last login:December 11, 2015, 10:03:43 am
« Reply #14 on: August 15, 2005, 11:03:23 am »
And glass makes that cool *click* when you put your quarter up to get the next game.   ;D
Bitten by the cabinet bug... obsessing ever since.
whatisk
« Reply #15 on: August 15, 2005, 06:40:32 pm »
Looks like glass it is then  ;D
DannyH
« Reply #16 on: August 15, 2005, 07:29:01 pm »
hmm I am strongly considering glass now.
I think at this point I will buy some foam core board and make a bezel to go beneath the glas then consider either glass or perspex from there.
still migh go pick up the sheets from brokenbones1 this weekend as well, becaus eif it works....sweet. Just have to convince the mrs to let me take the car for a day
Bones
  • [Moderator]
« Reply #17 on: August 15, 2005, 07:42:28 pm »
Tinted glass is obviously the best choice and seems to get the best reviews so I can understand the preference.
But I gotta say, the Lexan that I have is 8mm thick and is amazingly solid looking. It suffers from none of the warping or sagging I have read in other places.
DannyH
« Reply #18 on: August 15, 2005, 07:53:25 pm »
I think I will come grab the lexan and see how it goes, after all it may just be perfect for me. Otherwise I just got a quote for 6mm tinted glass cut at 500 x 600 for $AUD44 including GST
so thats not too bad either!
Bones
  • [Moderator]
« Reply #19 on: August 15, 2005, 07:56:11 pm »
Based on what I just paid, that price is very good.
DannyH
« Reply #20 on: August 15, 2005, 08:05:42 pm »
If you are interested here is the site I got that quote from
http://www.neilsglassservice.com.au/index.html
