Author Topic: Wiring an I-PAC 4  (Read 6031 times)
Willypill
  • Last login:October 12, 2005, 11:31:14 pm
Wiring an I-PAC 4
« on: August 14, 2005, 03:27:00 pm »
Does anyone have any tutorials on wiring my controls up to an I-PAC 4?  I'm about ready to do this..
Franco
Re: Wiring an I-PAC 4
« Reply #1 on: August 14, 2005, 03:34:18 pm »
Willypill
« Reply #2 on: August 18, 2005, 05:00:57 pm »
Ok, so can I just start wiring up my I-PAC 4 and stick the wires in any outlet on the I-PAC 4.  Then go into mamewah and configure it so that the buttons work for wherever I put them on the I-PAC 4?
Silverwind
  • Last login:September 26, 2022, 12:49:09 am
« Reply #3 on: August 18, 2005, 05:10:23 pm »
Well I wouldn't wire them to "any" outlet.. to make it easy on yourself wire player start 1 to P1 START, etc.
They are setup for MAME defaults so for a lot of games it will work without configuration.  Some games, like mortal kombat, the buttons need to be in a specific layout so there may be customization for that.
Wire it up, try it out, and customize from there.
Willypill
« Reply #4 on: August 18, 2005, 05:14:26 pm »
Ok, cool.
Got another question.  What is 1 SW 1?  Is that player 1's first button?
Willypill
« Reply #5 on: August 18, 2005, 05:17:23 pm »
Could you take a look at my CP and tell me how would be the best way to wire it to the IPAC 4.
http://img234.imageshack.us/my.php?image=dscf04284um.jpg
Tiger-Heli
    • Tiger-Heli
« Reply #6 on: August 19, 2005, 08:06:14 am »
Ok, cool.
Yes, by default.
Remember - 1SW1 sends L Ctrl, but you can do a lot of other things if you wanted to.
You could wire Button 1 to 1SW1 and off you go.
You could instead wire Button 1 to 1SW3 (Space), reprogram MAME so P1B1 was Space in all games, and off you go.
You could instead wire Button 1 to 1SW4 (L Shift), reprogram the I-PAC so 1SW4 sends L Ctrl and off you go.
Finally, you could instead wire Button 1 to 1SW5 (Z), reprogram the I-PAC so 1SW5 sends R, reprogram MAME so P1B1 was R in all games, and off you go.
I am just trying to point out that the input labels are guides, you don't have to really use them.
