Author Topic: Another Visual Pinball/Mamewah question  (Read 1950 times)
Scoobie
  • Last login:December 26, 2024, 12:53:48 am
« on: August 08, 2005, 09:09:43 pm »
After searching the boards, I haven't been able to find the answer to this.  I have a list of games/tables for Visual Pinball displayed in Mamewah.  Some of them don't work properly and others I simply don't play.
How do I remove the games I don't want listed?
When I go into the Games List Options, I have the following options:
     Add Game to List
     Remove Game From List
     Generate List
None of these options seems to do anything when selected.
I even removed the roms from my folders, but they still are listed in the MW list.
Any help on this is most appreciated!
whatisk
  • Last login:March 27, 2017, 06:41:39 am
  • Nothing to see here
Re: Another Visual Pinball/Mamewah question
« Reply #1 on: August 09, 2005, 09:32:27 pm »
If you remove some table files from where they are located, you will need to regenerate the game list in Mamaewah.
No trees were harmed in the creation of this post. Though several electrons were severely inconvenienced.
Scoobie
« Reply #2 on: August 10, 2005, 12:23:18 am »
That's part of the problem...when I try to generate list, it doesn't seem to do anything.   ???
whatisk
« Reply #3 on: August 10, 2005, 10:20:59 pm »
What method do you have Mamewah generating the list?
Can you post your ini file for visual pinball?
Scoobie
« Reply #4 on: August 11, 2005, 01:01:43 am »
Here is my ini...something must be missing. ???
whatisk
« Reply #5 on: August 11, 2005, 04:22:01 am »
Hmmm, your ini file seems pretty much identical to mine (except that I'm using Mamewah v1.61).
I know that with mine when I delete a vpt file in the tables folder listed in the ini file and regenerate it, the table I deleted is removed from the list.
I'm at a bit of a loss. Must be something simple though...
deadmoney5
  • Last login:February 03, 2020, 11:02:02 pm
  • I don't feel tardy
« Reply #6 on: August 11, 2005, 07:22:16 pm »
funny, I used your EXACT ini (other than the paths) and I can't get any tables to load....I just get stuck at the drug splashscreen..
whatisk
« Reply #7 on: August 11, 2005, 08:29:33 pm »
Whose, mine or Scoobie's??
If mine, then it works fine for me.
