Author Topic: Centipede sync problems?  (Read 4323 times)
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« on: August 08, 2005, 07:22:32 pm »
seems i am having problems with the the monitor sync on my restored centipede machine http://forum.arcadecontrols.com/index.php?topic=36900.0
tried to test it for the first time today but could not get the monitor to sync
i tried to adjust the pots on the hantarex remote control board but it just would not make the screen stable
any ideas what is going on here?
i tested the monitor when the cab was wired for jamma with a jamma board and it synced perfectly without need for any adjustment of the remote control.
could there be a problem with the centipede wiring harness or even the game board?
i would appreciate any advice?
SuperGunGuru
  • Last login:December 10, 2021, 08:14:53 pm
  • Filling up that basement
Re: Centipede sync problems?
« Reply #1 on: August 08, 2005, 09:04:21 pm »
I glanced at the centipede manual and it uses a horizontal and a vertical sync. Does the monitor use 2 seperate sync lines or just 1 composite sync? If it uses one, try hooking up both sync wires from the centipede harness to the single sync wire going to the monitor.
rchadd
  • Made in Cornwall
« Reply #2 on: August 08, 2005, 09:31:44 pm »
the monitor is hantarex MTC9000 i think
it has VS and HS connections on the monitor - i wired both up to the harness
then i thought i might have got VS and HS around the wrong way but when i reveresed the connections it still looked same
beginning to wondering if there is any sync at all getting from the centipede board to the monitor.
« Last Edit: August 09, 2005, 05:47:28 am by rchadd »
Ken Layton
  • Guru
  • Technician
« Reply #3 on: August 09, 2005, 12:55:12 am »
Some Centipede cabinets had TWO video/sync harnesses installed. One was for the pinout of a Matsushita monitor and the other harness was for the conventional Electrohome G07 monitor.
I'm pretty sure a Hantarex monitor is NOT ORIGINAL to the Centipede cabinet. Try running just the horizontal sync wire.
rchadd
  • Made in Cornwall
« Reply #4 on: August 09, 2005, 08:01:07 am »
it is definitely not an original monitor.
someone elsewhere mentioned that it might need to change monitor between +/- sync
could this be the cause that neither sync wires seem to be doing anything?
then again the monitor worked ok with a Hyper Olympics board + jamma converter when the monitor was wired upto a jamma harness.
how does sync output of centipede and hyper olympics compare? is one +sync and the other -sync?
anyone have a link to MTC9000 free docs?
i think there should be a jumper somewhere to switch from +sync to -sync on the the monitor chassis.
« Last Edit: August 09, 2005, 08:04:50 am by rchadd »
rchadd
  • Made in Cornwall
« Reply #5 on: August 09, 2005, 08:09:24 am »
found load of free schematics here
http://www.mikesarcade.com/arcade/monitors.html
cw
  • Last login:May 03, 2025, 09:26:58 pm
  • Game over man game over
    • The Cab
« Reply #6 on: August 09, 2005, 03:11:03 pm »
the composite sync is pin 12 on the centipede board off of the 12 pin connector. run that to your composite in.....
rchadd
  • Made in Cornwall
« Reply #7 on: August 16, 2005, 05:42:43 pm »
fixed it simply by switching the monitor form negative to positive sync (there is a toggle switch on the chassis pcb)
TurboC--
  • Last login:December 21, 2023, 12:23:05 am
  • No one can defeat the quad laser!
« Reply #8 on: August 16, 2005, 07:38:46 pm »
Those pictures are pretty.  ;D
