Author Topic: Ribbed belts etc used in Big Rig Truckin  (Read 2870 times)
coinguy
  • Last login:February 25, 2009, 08:57:46 pm
  • I wish I still had my Battlezone!
« on: August 07, 2005, 09:38:39 pm »
Looking for the stepper, ribbed belt, pulleys used in
Big Rig Truckin'
http://www.benchmarkgames.com/game_bigrigtruckin.htm
These parts move the roll down chute left and right.
« Last Edit: August 07, 2005, 09:51:57 pm by coinguy »
Bones
  • [Moderator]
Re: Ribbed belts etc used in Big Rig truckin
« Reply #1 on: August 07, 2005, 09:52:02 pm »
Is it a timing belt? Do you have a sample?
The numbers on the side will tell the pitch of the teeth and the length of the belt (or number of teeth). Then all you will need to do is measure the belt width.
Ring your local Gates or Dayco distributor with this information and they should be able to work it out pretty easy.
If you are stuck just post any numbers you can see on the belt and I should be able to cross reference the number for you.
*Edit: Closer read. You are after the timing pulleys?
« Last Edit: August 07, 2005, 09:53:54 pm by BrokenBones1 »
coinguy
Re: Ribbed belts etc used in Big Rig Truckin
« Reply #2 on: August 07, 2005, 10:05:44 pm »
I am looking for complete set to build a game of my own design.
Happened to see the game at movie theater after the show.
My eyesight is so bad I could not read anything.
I was already steaming the glass when attendant walked by while
son was winning many tickets.
If I can get more info from the manufacturer or by calling the
theater will pass it on.
Ed_McCarron
« Reply #3 on: August 14, 2005, 09:35:47 pm »
Big Rig Truckin'
If it is a timing belt (hard to tell from the pic...) I'm fond of Stock Drive Products...
http://www.sdp-si.com/
Free catalogs, lots of good info.  I've used thier stuff in robots and have always had a good experience.
coinguy
« Reply #4 on: August 14, 2005, 10:56:00 pm »
Thanks Ed!
Exactly the stuff I was looking for.
Now I can't wait for the catalogs to arrive.
Timing belts, steppers, slip joints,  oh I am a kid again!
