Author Topic: Has anyone used a spray gun to paint their cab  (Read 1537 times)
Silverwind
  • Last login:September 26, 2022, 12:49:09 am
« on: August 07, 2005, 03:44:21 pm »
Hello.  I am going to be building a cab pretty soon, just trying to get a few things planed out.  I already have a compressor and can easily go out and get a gun.
Has anyone here used an air compressor and a spray gun to paint their cab?  How did it turn out?
Q*Bert_OP
  • Oh yes, we did!
Re: Has anyone used a spray gun to paint their cab
« Reply #1 on: August 07, 2005, 04:40:01 pm »
Excelent, also consider using a paint roller
NY_in_TX
  • Last login:February 25, 2017, 11:19:54 am
  • First play's free...next one will cost ya
« Reply #2 on: August 07, 2005, 05:41:16 pm »
I have used both.
The spray ends up with a smoother glossier finish.  It turns out really nice.
The roller is more textured, but also very nice.
If you want a smooth as glass finish, you should spray it.
Now you need to prep more for spray and protect everything from overspray.  With a rolller you can just get to painting right away.
I had to think down my paint quite a bit, which in turn also meant I needed to do a couple more coats for good coverage.
johnvv
  • Last login:June 19, 2012, 08:36:20 pm
« Reply #3 on: August 07, 2005, 06:44:02 pm »
I'm restoting a Joust and have used a spray gun for the sides, spray can for the front, and roller for the top and back.  I have very little painting skill, but did spend some time reading and lots of time preping...
I highly recommend the spray gun.  Even my cheapie $100 HVLP home sprayer did a good job with proper preparation (see http://www.tutankham.com/painting.htm).  Much better than rolling or brushing - even for the unskilled.
For the front, back and harder to get areas on an assemble cab, I was happy with the spray can.  The roller was need for area that were too difficult to get with the sprayer and, despite sanding, priming, etc, still needed a direct application.
Since your cab is being built and in pieces to start with, I think spraying will come out great.  If you do have to thin your paint, save the extra or note the thinning ratio for any touch up needs after assembly and movinng.
Good luck!
John VV
