Author Topic: WG 19V2000  (Read 1390 times)
bestelec
  • Last login:August 07, 2005, 12:53:46 am
WG 19V2000
« on: August 05, 2005, 04:41:04 pm »
Having some deflection problems on a WG19V2000.  Not getting any top to bottom deflection on the center to left side of monitor display.  Top to bottom, center to right side of display is fine.  Looks like the left side of the display top to bottom left side to center is compressed on center line of display.  Yoke does not seem to have any major shorts in it.
So far have replaced both 2N3716's and 2N3792's most of the Transistors in the X and Y deflection circuits.  Can not really find any bad components in either the X or Y deflections circuits?
Brad
Ken Layton
  • Guru
  • Technician
Re: WG 19V2000
« Reply #1 on: August 05, 2005, 06:15:39 pm »
Bad solder joints on connector pins?
bestelec
Re: WG 19V2000
« Reply #2 on: August 07, 2005, 12:53:46 am »
Ken you are VERY GOOD!  I resoldered all of the connector pins and also steel wooled them too, resoldered all connecting wires and the WG19V2000 fired up fine!!!!
Again Thanks for your Help Ken!!
Brad
