Author Topic: UK Cable/Wire Suppliers?  (Read 2079 times)
Franco
« on: August 04, 2005, 01:40:24 pm »
I am after some multi-coloured wire to wire my CP. I have been given a few suggestions such as ethernet cable and bell wire but the wires in the ethernet cable I got (15-way) are far to fine. It has come in handy for hacking some DC pads but I am after something more substancial for the main CP. Ideally I am after a supplier that sells multi-colour wire similar to what is supplied in Ultimarcs wiring kits.
Any sources guys?
andy.p
  • Last login:August 19, 2005, 03:16:12 pm
Re: UK Cable/Wire Suppliers?
« Reply #1 on: August 04, 2005, 01:48:08 pm »
Hi Franco
I suppose it depends on how much you want but maybe somewhere like www.screwfix.com might be of help.
Or there's always your local B&Q
Franco
« Reply #2 on: August 04, 2005, 01:55:40 pm »
Thanks andy.p
I seached our B&Q superstore for some wire for my last CP. The most suitable thing I could find was seven core alarm flex but it was still to thin.
Ill go check out screw fix though.
ultramagnus
  • Last login:September 09, 2005, 02:10:45 am
« Reply #3 on: August 04, 2005, 04:46:28 pm »
Franco
« Reply #4 on: August 05, 2005, 01:52:59 am »
Thanks for the link. Seems that they only sell in bulk though, kinda 25m+.  I only really want a couple of meters. I may just end up buying a load and then selling some to other members if they want it.
« Reply #5 on: August 05, 2005, 05:19:33 am »
www.maplin.co.uk - I get most of my electronics stuff from here...not bad price and shipping is usually very quick.
Franco
« Reply #6 on: August 05, 2005, 05:57:58 am »
Yeah thats where I got the Ethernet mutlicore from. I couldnt really see anything else. Have you bought some suitable wire from there? Im looking for somewhere in the region of 24AWG (7/0.2mm).
« Reply #7 on: August 05, 2005, 11:04:44 am »
Yes, but I forget the gauge of wire (sorry)...some would argue the stuff I have is a bit thick, seems ok to me though and holds well in crimps, which can be a problem with thin stuff.
Franco
« Reply #8 on: August 09, 2005, 12:46:08 pm »
I emailed Maplins to see if they could recommend some cable from there stock but the nearest thing they have available (I wanted at least 12 strands at 22AWG - 7/0.2) was this cable:
http://www.maplin.co.uk/Module.aspx?ModuleNo=230&&source=14&doy=9m8
which is 7/0.1 i.e twice as thin as 22AWG and isnt thick enough.
Anyone else have any ideas? I may try emailing Andy to see if he will sell me 5m or so of each wire or if he knows of somewhere I can buy it from.
ultramagnus
« Reply #9 on: August 10, 2005, 06:00:22 am »
