Author Topic: Seeking advice from the Photoshop gods  (Read 1663 times)
Extreme8
  • Last login:August 24, 2008, 03:46:24 pm
« on: August 02, 2005, 07:29:37 pm »
Here's the issue I'm having.
Working with a Nascar theme (not sure if I'll keep with it but wanted to see how it looked), proving that there are rednecks even in Connecticut.
I've got a hi-res stockcar image that scales up to the size I'm using 6.5" x 27" with no problems. The NASCADE logo is vecorized.
I need some way to fill in the right side of the marquee from where the bitmap stops. As a test I just copied a portion of the asphalt and pasted it several times for a textured grey/black background. It's very obviously a copy and paste job. It looks fine when printed on an inkjet on plain paper at low resolution (basically looks like an even patch of mud on the printout), but it'll look terrible when printed professionally.
I need to find some technique that will allow me to either;
A - Do something similar to what I've already done but remove the hard edges and hide the fact that it's the same image pasted over and over again.
B - Create a texture that will blend in with the existing asphalt so I can use that to fill the rest of the marquee.
C - Something entirely different that I haven't even considered yet but one of the incredibly creative folks on this board will envision immediately.
Unfortunately I haven't been able to come up with anything I'm happy with and I'm looking for some Photoshop techniques that may help me along.
Any help is greatly appreciated.
Disgrntld
  • Last login:June 24, 2024, 08:31:59 am
  • Aiee
Re: Seeking advice from the Photoshop gods
« Reply #1 on: August 02, 2005, 08:18:11 pm »
How would it look if you applied a Gaussian Blur to the asphalt to knock out the repeat?
Woot, my first post =D
Extreme8
« Reply #2 on: August 02, 2005, 10:45:19 pm »
Thanks, but I already tried that.
It helps hide the edges but makes the curved rubber marks on the track stand out even more. Plus it softens the background too much and it looks kind of like a rain cloud.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #3 on: August 02, 2005, 11:11:43 pm »
There's no magic way to make it look like one long pavement... You just don't have enough "source" pavement to do it right. I would look for another image that would fit the space and do some blending to get both of them together seemlessly.
NO MORE!!
Stobe
  • Trade Count: (+17)
« Reply #4 on: August 02, 2005, 11:17:06 pm »
It looks like you could use "Extract" pretty nicely on the car and get it by itself.  Then you could scour the net for an asphalt texture to fill the entire background, behind your traced stock car.
If you need help with the extract, let me know.
-Stobe
Baker535
  • Last login:January 24, 2009, 11:16:40 am
  • Haha, Full member baby!
« Reply #5 on: August 03, 2005, 12:05:14 am »
The two easiest ways...
First would be to clip the car out and paste it on to a separate layer... then apply an underlay*
Second is take your current image on a layer and just feather the right hand side (easiest method is with a soft eraser). You can then place it over another underlay*
*The underlay can be anything from plain black, a gradient, a fill pattern of the asphalt or some custom graphics or collage... for example a faded checkered flag or a crowd of race fans.
Here's examples...
Baker535
« Reply #6 on: August 03, 2005, 12:06:09 am »
Feather...
« Last Edit: August 03, 2005, 12:13:55 am by Baker535 »
Baker535
« Reply #7 on: August 03, 2005, 12:14:59 am »
Created another one real quick...
Extreme8
« Reply #8 on: August 03, 2005, 07:59:54 pm »
Baker535, I like that last one. A lot. I think that one would work for me. You managed to blur the pavement really well and the checkered overlay is a great touch.
You said that was "another one real quick". With my elementary school level photoshop skills that would probably take me hours.
Any chance you could give me a little tutorial showing the steps you used to create it?
If I can't get it figured out maybe we can work out a deal for you to put that background together for me? (I don't expect you to work for free)
Thanks for your effort...
Baker535
« Reply #9 on: August 03, 2005, 11:51:28 pm »
Extreme8,
Sounds like a fun plan. PM sent...
-baker
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
« Reply #10 on: August 04, 2005, 02:28:06 pm »
Have you tried to cut the car out and place it on a larger pic of asphalt?  I don't have a nice asphalt pic but I'm sure there is one around somewhere you can grab.  Just use the marquee tool to cut out the car.
Next I'll be on fries, and that's when the big money starts rolling in.
