Author Topic: Mamewah without windows?  (Read 1672 times)
lettuce
  • Make It So!
« on: July 28, 2005, 12:40:52 pm »
How do u setup mamewah or indeed windows, so that when i turn my PC on it loads Mamewah straight away, without seeing windows at all?
UndeadMeat
  • Last login:June 18, 2007, 09:59:48 pm
  • Life keeps getting in the way of my cab building.
Re: Mamewah without windows?
« Reply #1 on: July 28, 2005, 02:00:54 pm »
roast
  • Last login:August 05, 2005, 06:06:37 pm
« Reply #2 on: August 04, 2005, 11:05:33 am »
hi there all. I don't know if anyone has done this up i do see a lot of people asking how to boot up straight into mamewah or other front ends.I was just setting up a new pc in my cabinet and stumbled on this cool way of doing it. just go to your controll panel and click on the power options icon click on the advanced tab and where it says (when i press the power button on my computer) select hibernate from the drop down menu, then go to the hibernate tab and check the box saying enable hibernate.click apply that's it.
run mamewah or your frontend then press your off button,your computer will save the state of you pc to the hard drive then shut down, when you press it again to start up your pc will start up in mamewah, an added bonus is that your cab will start up about 4 times faster than it did before.
I hope this helps some people out. or have you all thought of this already and I'm the last thicko to think of it lol.
let me know
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #3 on: August 04, 2005, 11:55:07 am »
You can read this thread too. It talks about my FE , but i think it could apply to MameWah too.
Go directly near the end of Thread , it is where there is the solution.
http://forum.arcadecontrols.com/index.php?topic=38316.0
