Author Topic: latest on Vertical Frontends?  (Read 1180 times)
bdsjake
  • Last login:September 18, 2017, 12:08:23 am
  • livefree
« on: July 27, 2005, 12:01:54 pm »
Hello!  been a while since I've been around, but getting the urge to build another cabinet.  First, I want to clean up the last one I built.  What are the current good frontends to use Vertically?
I probably will be using Win98SE - ArcadeVGA - Arcade moniter at 640@288.  I'd like to avoid DOS just because I don't have a lot of time to trouble shoot and figure stuf out, although I might if it is truly the best choice.
thanks,
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: latest on Vertical Frontends?
« Reply #1 on: July 27, 2005, 12:35:32 pm »
Hello, You can use my Front end vertically.
and it supports all arcadeVGA resolution.
It works on 98,2000,XP
I don't have lot of "pure" vertical layout (skin) avaibable in download , but you have a large choice of horizontal one you can use in vertical mode (the FE rotate it for you).
www.Atomicfe.com
PrizLucky
  • Last login:April 28, 2010, 09:42:32 am
  • It's good to be lucky
    • My arcade blog
« Reply #2 on: July 28, 2005, 01:48:42 pm »
my two cents:
I've set my machine (vertically) using Kymaera as the front end..
works great for me! easy to use, does everything I want/need... and it's a piece of cake to go vertical..
