Author Topic: Plexi monitor cover  (Read 2131 times)
Spectrum
  • Last login:January 09, 2014, 09:46:11 pm
Plexi monitor cover
« on: December 26, 2002, 04:43:34 pm »
Are most of you guys using a plexi or lexan "cover" in front of your monitor?  If so how did you attach it?  Did you make a frame to sit around it and hold it in or rout out channels on the inside of your cab sides and slide it in?  I plan on going to an arcade tonight after work to see if I can figure out the method they use, but IIRC I have never seen screws going through the protective plate in front of the monitor.
Told you I'd be back w/ more noob questions  ;)
Robert
OSCAR
    • Oscar Controls
Re:Plexi monitor cover
« Reply #1 on: December 26, 2002, 05:33:51 pm »
I made an attempt to explain this in this thread, but I
elfman12
  • Last login:November 20, 2010, 09:23:38 pm
  • FOTR, TTT, ROTK
« Reply #2 on: December 26, 2002, 07:26:49 pm »
I made an attempt to explain this in this thread, but I’m afraid my description wasn’t very clear.  So this time I’m including a couple of pics to help.
Nah, you were clear last time! :)
I've since arranged a way to make it work in my cab. On mine, I attached a 1X2 onto the cab below the monitor area, but behind when the CP fits. I notched it on the table saw about 1/2", and the lexan will snug down into that.
At the top, above the monitor in the top right and top left, it will attatch via a screw and post. I just picked up some little 1" round dowel rod "spacers" (about 1" deep also) at Lowes. They were cheap and I didn't have to cut them, hehe. I also picked up a threaded lug to hammer into the 2X4 in the cab, then glue the dowel spacers (with the same 1/4" hole drilled into it) over that lug-hole. Then, I'll fasten it with a 1/4X1" machine screw and screw cover.
I'll try and post some pictures later to make this clearer! (hard to do without images, unfortunately...)
In the orchard, drenched in blue light, she changes your bandages and soothes you.
