Author Topic: Act Labs Gun with T2??  (Read 1878 times)
Scotty
  • Last login:May 01, 2025, 09:16:56 am
« on: December 26, 2002, 02:37:23 pm »
Just got an Act-Labs light gun, and wanted everyone to know it is great, if you are thinking of getting one, just do like a famous sneaker company tells you... JUST DO IT!
I only have one question...  Can anyone get it to work with T2?  It worked great in Duck Hunt, Area 51, HOgans Alley and the rest, but I can not seem to get it to work with T2.
Revolution-X is broken, so I can not speak for it either, as it is on the same hardware.
Scotty
1UP
  • Token Junkie
    • 1UPArcade
Re:Act Labs Gun with T2??
« Reply #1 on: December 26, 2002, 02:47:15 pm »
T2 always needs to be calibrated before you play the first time.  Turn on the dip switch for test mode, go to the calibration screen and follow the instructions.
My other job...
Scotty
« Reply #2 on: December 26, 2002, 02:52:41 pm »
I tried, and it still didnt work.  X-axis was fine, but not y-axis.
Tried several times.
1UP
  • Token Junkie
    • 1UPArcade
« Reply #3 on: December 26, 2002, 03:18:36 pm »
Also try erasing the config files for T2 (I think the ones to kill are in the cfg and nvram folders) and recalibrate again.
My other job...
Xiaou2
  • Last login:Today at 06:07:59 am
  • NOM NOM NOM
« Reply #4 on: December 27, 2002, 08:53:19 am »
 I believe I got it to calibrate... but, it was only for a test.
 T2 uses pot based guns... and also, a rapidfire trigger.
 The Actlabs gun isnt capable of having the trigger held down to fire - because it cant do realtime tracking.
  So basically... its useless to play T2 with the actlabs gun.
