Author Topic: Marquee retainer and hinges  (Read 2356 times)
Steve Kaz
  • Last login:May 11, 2011, 01:13:25 pm
« on: July 25, 2005, 11:03:38 am »
I'm almost done with my cab and starting to think about the last piece, i.e. the marquee retainer and marquee.
I got the retainer from Happs and was going to screw it in the top and bottom, but then i started thinking about when i'd have to replace the light bulb that is behind it.  I'm thinking of putting hinges on the top half and screwing in the bottom half.
Has anyone else done this?  I'm sure that are probably even better ideas out there (as i want to hide the hinges as much as possible
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Marquee retainer and hinges
« Reply #1 on: July 25, 2005, 12:06:26 pm »
You could hinge the bottom board.
NO MORE!!
Steve Kaz
« Reply #2 on: July 25, 2005, 12:15:26 pm »
That has my speakers attached to it and it's mounted pretty solid already.  I'll have to post a picture later to show you all what i mean.
Then again, i probably can't hinge the top and still put a retainer over it.  I might just have to screw the whole thing in and just remove them when the light needs changed.  Eventually though the MDF will wear out.
RayB
  • There's my post
    • RayB.com
« Reply #3 on: July 26, 2005, 11:58:14 am »
You could install t-nuts on top, and use bolts to hold the marquee retainer. That way you can remove the retainer over and over with no problem. Remove the retainer, then slide out the marquee and there you go, access to the insides.
NO MORE!!
kickngas
  • Last login:April 19, 2017, 12:29:04 pm
  • "You get my Cheez Whiz boy"?
« Reply #4 on: July 26, 2005, 10:35:36 pm »
How often would one need to access the light?  The T-nut idea is a good one for the life of the machine.
