Author Topic: Sound Help in Mame & Mamewah  (Read 2150 times)
topdawgg
  • Last login:April 01, 2012, 05:03:13 pm
« on: July 25, 2005, 04:04:56 am »
Alright guys im pretty new to everything and yes I have done a ton of reading and a ton of research.
« Last Edit: July 25, 2005, 04:31:49 am by topdawgg »
Re: Sound Help in Mame & Mamewah
« Reply #1 on: July 25, 2005, 05:11:00 am »
As a side note, if Mame runs with no sound, how do i set up the config file in mame to run no sound all the time ... I could use this just to test the mamewah theory.
From a command promt:
mame -cc
...then edit mame.cfg and set sound 0.  As you say, this will test your theory...
topdawgg
« Reply #2 on: July 25, 2005, 01:19:06 pm »
I already have the config file up and running and I will change it to 0 to test my theory ... still what can I do to make the sound work?
ahmer
  • Last login:March 16, 2014, 02:40:21 pm
  • Do as you like.
    • IC Markets Rebates and Discount
« Reply #3 on: July 25, 2005, 05:14:29 pm »
mame -cc
minwah,you are making this thread confusing :-\
mame.cfg file does not exist in mame (windows command line).
mame.ini should be there.
I can post the mame.ini file and mamewah.ini file here if anyone needs them.  I am pretty sure I just missed a setting ... or is there a conflict with dos trying to access the sound card?
topdawgg,First you should care just for running mame with a command promp and make sure that you have a windows command line version of Mame(Not a Dmame).
As you mention your hardware Use a letter version of mame like mame 98.
be aware that your sound card and mixer drivers are properly installed.
check your mame.ini file.
« Reply #4 on: July 25, 2005, 05:30:35 pm »
Actually, you are confusing things  :P.  MAME v0.36 is DOS based, as it was before Windows became the main build.  Therefore mame.cfg will be used instead of mame.ini.
As for getting dos sound to work in XP, I've no idea :(
« Reply #5 on: July 25, 2005, 05:32:21 pm »
This is good advice, you might want to try MAME v0.55 instead of the latest version tho, it will run faster on that system.
ahmer
  • Do as you like.
« Reply #6 on: July 25, 2005, 05:43:20 pm »
Actually, you are confusing things  Tongue.  MAME v0.36 is DOS based, as it was before Windows became the main build.  Therefore mame.cfg will be used instead of mame.ini.
OoopSss...   Sorry Minwah. :-\
I never used an old 0.36 version of mame.  :)
btw,Mamewah only supports windows command line version of mame. :P
topdawgg
« Reply #7 on: July 25, 2005, 06:57:27 pm »
Wow Thanks guys for all the replies... I guess what I will try is to update to mame 0.91 ( I have access to those roms ) and then try everything again.
I just didnt want to re download all the roms (the ones i own that is).  Well back to the drawing board...
Makes me kinda frustrated that I cant even get the emulator to work, how the in the heck am I going to get the CP to work *sigh*
« Reply #8 on: July 26, 2005, 08:50:33 am »
Wrong again ;)  I only *recommend* Windows commandline MAME.  DOS MAME, and MAME32 will work ok too, if you know what you're doing.
topdawgg
« Reply #9 on: July 26, 2005, 09:00:09 pm »
Well I would like to know what im doing and make anything work... but i guess in this case the upgrade worked for now ... although half the roms are dead((
« Reply #10 on: July 27, 2005, 04:59:47 am »
Try using ClrMAMEPro - it should be able to fix some of them.
