Author Topic: Star Wars problem - resets  (Read 3837 times)
johnvv
  • Last login:June 19, 2012, 08:36:20 pm
« on: July 21, 2005, 11:57:25 pm »
I have a completely restored Star Wars upgright that was fully working about 4 months ago.   It was left in dry storage during the interim and recently moved inside.
Since it has been moved, it randomly resets during gameplay.  The entire reset takes about 2 seconds and the play is returned to the initial 'welcome' screen.  The monitor does go blank during the reset.  Any ideas of what the source might be?  Or a resource to check for more info?  Based on my computer experience, it looks like a complete board reset is happening.
I checked the worn power cord and replaced it with a new one.  The ampliphone HV transformer was replaced during the restore and is fine.  The internals are clean.
Thanks for any suggestions or ideas.
pcb
  • Last login:September 25, 2019, 05:27:26 pm
    • MikesArcade.com
Re: Star Wars problem - resets
« Reply #1 on: July 22, 2005, 12:21:37 am »
Did you check all the connections inside the cab?   Reseat connectors, etc?  Just a guess.
 - Mike -
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #2 on: July 22, 2005, 12:22:03 am »
Did you re-seat the main connector that attaches to the game board(s)?
NO MORE!!
paigeoliver
  • Awesome face!
« Reply #3 on: July 22, 2005, 06:20:52 am »
Replace the big blue cap if you haven't already.
Check the voltages first though. Low voltages are the most common cause of a reset.
Goz
  • KOTA
« Reply #4 on: July 22, 2005, 09:51:06 am »
I had a similar issue with my Star Wars cab when I first got it and it went away after I pulled the game board and pressed lightly on the chips to make sure they were seated properly. After sliding the board back in it worked. I did separate the main board from the sound board and reseat that connection as well.
Hope it helps
-Goz
« Reply #5 on: July 22, 2005, 10:03:53 am »
When he moved it, some solder joints probably went cold.  Examine the back side of the PCBs carefully.  This one could be a ---smurfette--- to find.  When moving these Atari cabs it's very common for solder joints to break and become intermittent.
Since the whole game is resetting, I would definitely start with the ARII and the power supply.
Paige's suggestion is a good one, too, make sure all connectors are seated properly and have strong connections.
johnvv
« Reply #6 on: July 24, 2005, 03:15:52 am »
Thanks for the suggestions.  I checked and reset all the connectors, but the problem continued.  I think the 'big blue' cap was replaced just before I bought it - I'll check with the seller - it looks new.
I decided to to a self-test.  While no errors were found, I think the problem may have been related to either the self-test switch or aux coin switch.  After flipping both of them several times for tests, the problems *appears* to have gone away.  It hasn't happened in several hours, which is a record since I moved it inside.
Checking voltages is beyond my ability to do safely, so I'll have someone more experienced do that if the problem recurs.
Thanks again all!!
« Reply #7 on: July 25, 2005, 09:52:59 am »
Oh, yeah, those switches.  They didn't age well.  A lot of people remove them for home use.
johnvv
« Reply #8 on: August 11, 2005, 10:50:10 pm »
To complete this thread for future use by others...
the reset problem recurred a few days after I adjusted the internal reset and test switches.  Turns out the problem was the 'big blue' capacitor.  It's been replaced and the assualt on the Death Star has resumed...
I also noticed that the unit was making a noticeable humming noise recently (like a ground loop sound in home theater systems).  That has also decreased significantly with the new cap.
Thanks all for you suggestions and help.
« Reply #9 on: August 12, 2005, 09:56:46 am »
The hum was AC ripple in the power supply.  Replacing the cap will definitely take care of the AC ripple, since it is the cap that is responsible for keeping a smooth, constant output rather than pulsing output.
