Author Topic: Connecting Console Controllers 2 a PC...  (Read 3069 times)
Flappz
  • Last login:March 22, 2013, 06:42:37 am
  • My 6 Year Old Plays ATARI BITCHEZ!
« on: July 21, 2005, 08:47:12 am »
Ladies Ladies Ladies!!!!!
I have Connected 2 NES controllers to my paralell and USB (for Power) ports.  Now,  you can connect 4 maybe 5 NES & SNES controllers to the paralell port and it will run no problem.  What I am wondering is, is it possible to connect 4 Sega controllers to the parallel port? I want to be able to connect 4 controllers so I can have a full game of NBA Jam.
Please send any suggestions!
Philip
Re: Connecting Console Controllers 2 a PC...
« Reply #1 on: July 21, 2005, 11:37:32 am »
Not sure, but I would first see whether your chosen emulator supports 4 pads...and also see how NBA Jam handled 4 pads (did it have extra ports on the cartridge?).
daywane
  • GRRRR!
« Reply #2 on: July 21, 2005, 12:54:42 pm »
congrats on the nes and snes.
waiting for my chips to come in the mail so I can just go usb.
hope they are here by monday  ;D
Flappz
« Reply #3 on: July 21, 2005, 10:01:47 pm »
1st I was gonna go USB but its so much cheaper going paralell.  A Lot Cheaper and easier. (like its that much easier)
2nd Many Emulators allow 4 controllers even for NES.  NBA Jam Does work with 4 controllers perfectly.
I have seen the schematic for 4/5 nes andsnes but have only seen 1 Atari and Sega.  I want atleast 2 controllers, hopefully 4...lalala I got a atari 2600 controller for 25 cents today, in great condition at a garage sale.
FLappz
Adeptus
  • Last login:May 31, 2006, 11:25:07 pm
  • Putting the 'Mad' back in (computer) science
« Reply #4 on: August 10, 2005, 11:34:06 pm »
You can do 2 Atari (or Master System, maybe not Genesis) to the gameport. I've seen a couple of different sites that have full schematic & instructions...
You should be able to do it through parallel as well, haven't looked into that myself.
ultramagnus
  • Last login:September 09, 2005, 02:10:45 am
« Reply #5 on: August 11, 2005, 03:21:17 pm »
if you dont mind hacking your pads apart its not hard to hook up quite a few to the keyboard port
but (if like me) you still want your pads to be usable on a megadrive then im as stuck as you, i only have 2 paralell ports and one of those is hooked up to a printer
i was thinking about using a usb to parallel adaptor but those only work on printers, which only leaves using a usb to serial adaptor and then using a serial to parallel adaptor, which isnt the most elegent of answers
Setabs
  • Last login:March 07, 2015, 03:03:23 pm
  • 100% MAME compatible.
    • Another Useless Webpage
« Reply #6 on: August 12, 2005, 04:36:42 pm »
Why not go all usb.  The retrozone kits can supposedly be used after they connect to there appropriate connector.  so use regular controller.  make a box that has the nes, sega, snes connection on it.  turn it to usb and then run that to the computer.
ultramagnus
« Reply #7 on: August 13, 2005, 10:54:01 am »
i dont like ordering from the US
Adeptus
« Reply #8 on: August 14, 2005, 01:19:57 am »
The impression I got from their site is that the chips are different for the different controllers (well... I think NES & SNES use the same communications). So if you're building a NES/SNES/SEGA to USB then you would need 2 or 3 chips & a USB hub...
Silverwind
  • Last login:September 26, 2022, 12:49:09 am
« Reply #9 on: August 21, 2005, 11:16:32 am »
Check out this hack, it lets you wire it right to your keyboard encoder. (NES and 3 button genesis)  You can change out the wire on the controller or get your own connector.
Original post:
http://forum.arcadecontrols.com/index.php?topic=14183.0
Link to his site:
http://dawgslair.com/joypad/joypadhack.html
« Last Edit: August 21, 2005, 11:18:20 am by Silverwind »
Adeptus
« Reply #10 on: August 21, 2005, 08:13:51 pm »
Yes but that involves hacking your pads & making them unusable on the original.
If it let you plug unmodified controllers straight in, I'd be impressed.
Silverwind
« Reply #11 on: August 21, 2005, 10:27:09 pm »
if you want an unmodified controller you will probably need to buy one of the usb converters..
I would either go USB or hack the controllers so you can use a keyboard encoder.
« Last Edit: August 23, 2005, 11:34:11 pm by Silverwind »
ultramagnus
« Reply #12 on: August 22, 2005, 04:19:58 pm »
well, that wasnt very helpfull
