Author Topic: Street fighter Alpha 3 time switch?  (Read 8448 times)
motorfish
  • Last login:September 30, 2009, 03:35:08 am
« on: July 20, 2005, 12:43:19 pm »
Hey All.
I had read on the CPS2Shock website that it is possible to set the "time switch" to 4 and access the time released characters such as Balrog, Juni and Juli, without having to keep the machine on for a month.
They say howe to do this, but fail tosay where you need to input these changes.
I'm using MAME32, and I've checked the sfa3.ini file, but there is no "time" file to alter. I tried adding one, but that didn't work either.
There doesn't seem to be an option in MAME32 itself to change such a setting.
Does anyone here know how to do this? I'm really stuck here.
- Dan
Have you paid your dues Jack?......Yessir, the check is in the mail!
walls83
  • beer is good
Re: Street fighter Alpha 3 time switch?
« Reply #1 on: July 20, 2005, 01:17:27 pm »
Im interested in this also.  Motor if you find out could you post if someone else doesnt.
motorfish
« Reply #2 on: July 20, 2005, 02:01:58 pm »
I found it. It looks like it's as simple as enabling cheats for the game.
Problem, is that they're not saving after the Player exits the game, and then re-enters.
A few more tests.
- Dan
walls83
  • beer is good
« Reply #3 on: July 20, 2005, 03:55:26 pm »
what cheat are you enabling? Are you playing the US version of Japan version?
Marky_1979
  • Last login:January 03, 2017, 11:07:07 am
    • Personal Webspace
« Reply #4 on: July 20, 2005, 04:06:32 pm »
I love this game would be interested to hear how this works out
motorfish
« Reply #5 on: July 20, 2005, 07:12:19 pm »
US version, Alpha 3.
- Dan
TalkingOctopus
    • My Arcade
« Reply #6 on: July 20, 2005, 11:14:22 pm »
This is not an option you are going to find in an ini file or in MAME32.
« Last Edit: July 20, 2005, 11:44:18 pm by TalkingOctopus »
TalkingOctopus
    • My Arcade
« Reply #7 on: July 22, 2005, 12:41:13 am »
I got a PM asking for more detailed instructions, so here we go:
1) Download the cheat.dat from: http://cheat.retrogames.com/
2) Put it in the same directory as mame.exe
3) Enable cheats by setting cheat to 1 in mame.ini
          - If you don't have mame.ini, run mame.exe -cc
4) Press tab and navigate to the enable cheat menu.  Put color unlock to green.
5) Reset (f3)
6) Choose your fighter.  To select balrog, leave the cursor on karin for 5 seconds.  Then move to random select hold start and press a button. (Look up how to select the other fighters)
To enable the cheat on mame startup, add the line above to your cheat.dat file.
iamnaeth
  • Last login:August 08, 2018, 02:42:59 pm
« Reply #8 on: July 22, 2005, 08:46:05 am »
Is there any way to use the cheat file without all the numbers on the side of the screen?
CrazyTerabyte
  • Last login:January 24, 2024, 08:09:58 am
    • My site
« Reply #9 on: October 03, 2005, 11:19:19 pm »
I've found a way to edit SFA3 NVRAM file to unlock all time-based secrets. It is only needed to change one byte in NVRAM. I've documented everything in this page:
http://denilsonsa.hn.org/~denilson/sfa3.html
You may also download a ready-to-use NVRAM there.
darthbane2k
  • Last login:September 30, 2009, 04:54:06 am
  • Built the cab, just need the time to play!
« Reply #10 on: October 06, 2005, 06:00:53 am »
Okay, can someone confrim that if I download this ready to use NV file, it will enable all hidden fighters (is Guile one?) while NOT displaying numbers and code on the side of the screen?...
pointdablame
« Reply #11 on: October 06, 2005, 10:10:00 am »
why not just try it out for yourself? It'd take 2 seconds.
first off your and idiot
CrazyTerabyte
    • My site
« Reply #12 on: October 08, 2005, 12:47:48 am »
AFAIK, guile is not available in Arcade version. Read this:
http://en.wikipedia.org/wiki/Street_Fighter_Alpha#Street_Fighter_Alpha_3
In addition, to play with hidden characters or hidden battle modes, you need to use some special "codes" (like: press LK+MK+HK). They are described in "History" info inside MAME (supposing you have history.dat). They are also available in one of the links on my page (the one with NVRAM file).
About those numbers... I think they are from some cheating options you may have enabled. With the "hacked" NVRAM, you can disable cheats (and the hiscores will be saved when you close MAME, which does not happen with cheats enabled).
motorfish
« Reply #13 on: October 08, 2005, 01:01:55 am »
Correct. Guile is only available in Street Fighter Zero 3 Upper, which wasn't released in the arcades here in the states.
- Dan
CrazyTerabyte
    • My site
« Reply #14 on: February 16, 2006, 06:00:04 pm »
Since hn.org service is closed, the above URL will stop working anytime. If that happens, try one of the following:
http://denilsonsa.homelinux.org/~denilson/sfa3.html
http://denilsonsa.selfip.org/~denilson/sfa3.html
Ah, if anyone wants to mirror that page and that file, feel free to do it.
  • Last login:Yesterday at 07:46:44 pm
« Reply #15 on: February 18, 2006, 10:53:17 am »
Guys this question comes up about once every month or so.  You should really try teh search function before you post.
Also, time-released characters are even covered in the mame faq if I'm not mistaken.
