Author Topic: AT Power Supply Questions  (Read 1268 times)
testicle187
  • Last login:January 24, 2026, 06:08:15 pm
« on: July 19, 2005, 02:55:24 pm »
I am in the process of wiring a seperate AT power supply to power the fans on the on rear of my arcade cabinet and am wondering what I need to do to get it where when I flip the power supply Switch to "ON" it starts the fans running.  Is there a set of pins I need to short out?  Or perhaps a walkthrough for hacking an AT power supply on this?  Thanks in advance for the help.
Franco
Re: AT Power Supply Questions
« Reply #1 on: July 19, 2005, 03:05:13 pm »
Do you mean AT or ATX?
AT PSUs dont need the pins shorting, ATX do.
The lower part of this thread should help.
http://forum.arcadecontrols.com/index.php?topic=38468.0
testicle187
« Reply #2 on: July 19, 2005, 05:12:35 pm »
Mine is actually AT, but I was wondering how I would go about disabling the Power button that is attached to it.  So that when the switch on the back of the PSU is turned on it powers up.  I know I can leave the front power button clicked in, but was wanting to eliminate some wires if possible.
spystyle
« Reply #3 on: July 21, 2005, 11:47:34 pm »
IIRC,
AT PSU has a toggle switch, meaning it's always ON or always OFF, no momentary business. If that's true you could turn the AT power supply ON and connect it to a "smart strip" that is connected to your cabinet's PC, then it would turn on and off with the PC.
As for "eliminate some wires" - simply cut the wires off that you aren't using. (probably all but 2)
What is the AT PSU being used for?
« Last Edit: December 09, 2006, 10:10:47 am by spystyle »
