Author Topic: Mamewah Layouts  (Read 2456 times)
Exarch
  • Last login:December 07, 2009, 08:04:55 pm
Mamewah Layouts
« on: July 19, 2005, 07:44:50 am »
hi,
i have been working hard to setup the PC ready for a cab i plan to build, but in my way of round about ways to do things, i have decided to sort out the software /frontends and emulators first.
i am using mamewar 1.61 and am trying to set up custom layouts for each emulator on the system (13 in total) i can use the layout editor ok, but for some reason i cannot see the background image.  (it's just kind of greyish)
also i cannot figure out how to set up an individual layout file for each emulator.
any help would be great
Re: Mamewah Layouts
« Reply #1 on: July 19, 2005, 10:14:07 am »
This should help:
http://mamewah.mameworld.net/docs/layouts.txt
If you can't see the background image, make sure the object backgrounds are set to transparent (use the layout designer) so you can see the background behind them.
Exarch
Re: Mamewah Layouts
« Reply #2 on: July 20, 2005, 08:01:29 am »
ok by reading that, i assume...
i have an atari2600.ini so i shold therefore have an atari2600.lay
this will basically make the layout for the atari2600 only refer to the lay file??
is that right?
sorry cannot check, my computer is offline for a couple of days
Re: Mamewah Layouts
« Reply #3 on: July 20, 2005, 08:03:13 am »
Exactly.  Just by that correctly named .lay file being there Mamewah will know to use it (assuming you have the layout name set appropriately).
jcrouse
    • CPViewer
Re: Mamewah Layouts
« Reply #4 on: July 20, 2005, 08:06:15 am »
is that right?
That's correct. And your files should be, atari2600-main.jpg, atari2600-message.jpg, atari2600-options and so forth. Also, if you want to order the layouts other that alphabetical most of us put a numeric prefix on the fromt like 000_atari2600-main, 010_atari5200-main.jpg and so forth.
John
Exarch
Re: Mamewah Layouts
« Reply #5 on: July 21, 2005, 09:57:40 am »
ok, that makes alot of sence, i will be able to try it all out tomorrow and i'll get back to you.
thanks
Exarch
Re: Mamewah Layouts
« Reply #6 on: July 22, 2005, 01:11:26 am »
ok, here is the progress
i have been able to set up a layout.lay (no background) and an atari2600.lay as i have an atari2600.ini
the layout is fine, so i know they are now switching, however the background for the 2600 (atari2600.jpg) is not showing up in mamewah, it is however showing up in the layout designer.
in mamewah i have just got a grey screen background when i change to the 2600.
progress is being made, but still need some extra help ;D
thanks for the assistance so far guys
Exarch
Re: Mamewah Layouts
« Reply #7 on: July 24, 2005, 10:29:34 am »
still no luck with the background, i have checked the size of the file 800x600 and have set the background size to 800 x 600 also.
i'm lost ???
Fat_Trucker
  • Last login:September 08, 2010, 11:44:22 am
Re: Mamewah Layouts
« Reply #8 on: July 24, 2005, 12:15:21 pm »
As I think jcrouse pointed out, check the filename for that background file. It should be named 'atari2600-main' not 'atari2600.jpg'.
All files should sit in the same layout folder so in the layout folder you are using you should have the files atari2600.lay and atari2600-main.
Put all your other custom layouts and their respective backgrounds into the same folder.
« Last Edit: July 24, 2005, 01:03:24 pm by Fat_Trucker »
I didn't touch it....honest!
Exarch
Re: Mamewah Layouts
« Reply #9 on: July 24, 2005, 09:41:59 pm »
cool, i'll give that a try tonight.
thanks
Exarch
Re: Mamewah Layouts
« Reply #10 on: July 25, 2005, 08:27:14 am »
Woo HOO!
got it all figured out,
Thanks to everyone for their help.
