Author Topic: Fades out to black  (Read 2626 times)
unrestricted
  • Last login:November 04, 2010, 04:31:53 am
Fades out to black
« on: July 18, 2005, 03:33:41 am »
Hi,
I have recently recieved an arcade machine which i have wired up for MAME use. The monitor is flaky at the moment as when i turn it on the screen appears for about 30seconds to 1 minute, then it fades to black and doesnt come back on.
I can still see an orange glow near the bottom of the tube but there is no picutre.
When the monitor works it has slight faint white lines across the screen, how can i remove these and fix my monitor?
There are two stickers on the tube, one saying it is a KAGA Electronics KZ-20N-L and another saying Mitsubishi 510UKB22. The monitor is about 19-20".
Thanks for your help!
Ken Layton
  • Guru
  • Technician
Re: Fades out to black
« Reply #1 on: July 18, 2005, 10:19:30 am »
That's an old monitor. First thing is install a capkit. Kaga monitors are rebranded Nanao monitors.
unrestricted
« Reply #2 on: July 18, 2005, 06:02:43 pm »
Could you suggest where i could find a capkit for sale?
StephenH
« Reply #3 on: July 18, 2005, 06:20:27 pm »
alundra
  • Last login:February 02, 2009, 09:30:05 pm
« Reply #4 on: July 20, 2005, 12:56:19 am »
i had the same problem like you..i'd re-adjust the -5v&+5v on the power supply then the problem gone...hopes it help
unrestricted
« Reply #5 on: July 22, 2005, 12:54:06 am »
could you please explain what you mean be re-adjusting the +5 and -5?
alundra
« Reply #6 on: July 24, 2005, 03:17:36 am »
i adjust them to as close as 5/-5 volts as i can..
