Author Topic: Are arcade monitors compatible with all cabinets??  (Read 1142 times)
eggedd2k
  • Last login:February 14, 2006, 09:38:56 am
« on: July 17, 2005, 10:32:01 am »
this might sound like a daft question but do all relevant sized arcade monitors fit in all cabinets? reason i ask is because i'm looking at replacing the monitor in my cab.  It's a 19" one in there at the moment and bolts to the cabinet front (from the inside).
It's got a pcb with it which the rgb etc cables from the jamma edge connector go to (there's a 6 pin male connector on the board for this).
thanks
pcb
  • Last login:September 25, 2019, 05:27:26 pm
    • MikesArcade.com
Re: Are arcade monitors compatible with all cabinets??
« Reply #1 on: July 17, 2005, 02:55:05 pm »
Arcade monitors don't always have the same bolt patterns in their frames.
« Last Edit: July 17, 2005, 03:08:15 pm by pcb »
eggedd2k
« Reply #2 on: July 17, 2005, 04:22:04 pm »
thanks mike. i thought that might be the case. i guess it'd be easy enough to drill new bolt holes.
