Author Topic: Coin Mech, credit change??  (Read 1518 times)
lettuce
  • Make It So!
« on: July 17, 2005, 06:39:36 am »
Does anybody know it this digram means that i can changed the amount of credits for 1 play?? Also what does inhibit mean in coin mech terms??
Ken Layton
  • Guru
  • Technician
Re: Coin Mech, credit change??
« Reply #1 on: July 17, 2005, 11:37:35 am »
Inhibit means reject or lockout a certain denomination. Suggest contacting the manufacturer www.meiglobal.com for instructions on your particular mech.
eggedd2k
  • Last login:February 14, 2006, 09:38:56 am
« Reply #2 on: July 17, 2005, 04:31:43 pm »
you'll need a credit board to be able to specify how much it is a go - it connects to the pins on the bottom left of the picture.
you'll get one from swallow amusements
lettuce
  • Make It So!
« Reply #3 on: July 19, 2005, 01:39:05 pm »
Yeah ive got one, here
I want to also be able to get this to work with my mame cabinet, i take it the wires that supply the power are run from the Coin mech to the credit broad and finally to the multi power supply that i removed right? Would these be a red wire and a Black wire? Can i connect the +12 V wire (red?) and Ground (black) wire from the credit broad to my PCs +12V & GND wires, and then it will all work?
I have noticed that from the credit broad, a red & black wire runs to a analog counter just inside the coin door, would these also be the Live (+12v) and GND wires?
« Last Edit: July 19, 2005, 01:42:03 pm by lettuce »
eggedd2k
« Reply #4 on: July 19, 2005, 04:36:26 pm »
just had a look at mine and from what i can tell it's the same as yours
lettuce
  • Make It So!
« Reply #5 on: July 19, 2005, 04:50:20 pm »
I made a mistake, the +12V wire is the yellow wire not the red (thats +5v). Egg have u got ures hooked up to your PCs power supply then? And you know what the jumpers settings are for credits etc?
eggedd2k
« Reply #6 on: July 19, 2005, 04:55:22 pm »
not mine get's it's power from the psu in the cabinet.
check out switch position info here for the most common credit boards: http://www.coin.demon.co.uk/credit.htm
