Author Topic: Mamewah - Error in SFX_InitialiseDS - Help!!!  (Read 5931 times)
jhuie
  • Last login:April 10, 2013, 12:12:12 am
« on: July 14, 2005, 12:28:40 am »
Ok, I set up Mamewah as I thought it should work and get it bombs out and leaves this message in the log:
"Automation error in SFX_InitialiseDS"
Any thoughts?  I'm running Windows XP, DirectX 9.0c, loaded the little extra support files.  I'm stumped.  I looked EVERYWHERE I could think of for something on this error and have no clue.  Oh, and it's an Athlon 3000 processor with a fresh install of everything.
Could it be that I shouldn't have installed 9.0c?  I can't figure out how to remove it to go back.  I reinstalled Window XP over it to try that but I'm still getting the same error.
Anyone out there smarter than I am?  It wouldn't take much.... :)
As Dave Letterman used to say, "Sumbuddy peas hep me!"
Re: Mamewah - Error in SFX_InitialiseDS - Help!!!
« Reply #1 on: July 14, 2005, 04:52:22 am »
This usually means you don't have DirectX installed...but you do  ::)
Check that your soundcard is DirectX compatible, sometimes they are not, which would also cause this error.
Bill Mote
  • Last login:May 29, 2010, 11:04:28 pm
  • Focus on making things better not bigger.
    • Things That Make Me Mad and How To Fix Them
« Reply #2 on: July 14, 2005, 08:36:19 am »
Can you hear sound from your computer?  If it's a fresh load of XP then you may not have the drivers for your sound card loaded yet.  I just installed a buddies PC with XP for Mame and was getting the exact same error.
The SFX_ was a pretty clear give-a-way that it was sound card related.  I didn't have speakers attached so I had no clue there was an issue.  When I looked in device manager the audio device was under the "?" section.  Stupid old Compaq onboard audio ;)  Added the drivers and the problem went away.
dot
« Reply #3 on: July 14, 2005, 10:37:51 am »
Just for some extra info, the 'InitialiseDS' part means InitialiseDirectSound...so for some reason DirectSound (part of DirectX) is having problems.  99% of the time this is due to hardware or driver issues.
jhuie
« Reply #4 on: July 15, 2005, 11:20:27 pm »
Thank you.  You were right....sound drivers weren't loaded.  Thank you!  I was banging my head on the wall over this.
Greenskein
  • Last login:January 16, 2008, 09:14:15 pm
« Reply #5 on: December 17, 2007, 10:21:02 pm »
This is years later, however, just had the same problem with an old PC I was trying to run my mamewah setup on...I read the above posts, took a look at the motherboard and noted down the model number, did a google search and found the driver downloads for the on board audio at the motherboard maker's website...installed the drivers no problem and then my setup ran just fine...
gaijin4life
  • Last login:February 18, 2008, 06:31:14 pm
« Reply #6 on: February 03, 2008, 03:47:57 am »
Check your device manager to make sure all your sound drivers are installed.  This seems to be a sound-related error.  I installed machine-specific RealTek Audio drivers and it went away for me.
