Author Topic: Pics of my new cab - any suggestions for changed/upgrades?  (Read 3833 times)
eggedd2k
  • Last login:February 14, 2006, 09:38:56 am
« on: July 11, 2005, 06:56:29 am »
Picked this cab up a few weeks ago for
« Last Edit: July 11, 2005, 08:44:21 am by eggedd2k »
paigeoliver
  • Awesome face!
Re: Pics of my new cab - any suggestions for mods?
« Reply #1 on: July 11, 2005, 07:04:09 am »
Yes, get rid of those terrible gambing buttons and get some buttons designed for playing games.  ;D
eggedd2k
« Reply #2 on: July 11, 2005, 07:19:41 am »
yeah i had some regular buttons all lined up but the buttons on the photo have a smaller diameter than regular buttons.  I dont want to drill bigger holes.  Can you get buttons of different diameter still off the net?
eggedd2k
« Reply #3 on: July 11, 2005, 07:37:36 am »
Can someone move this thread to the Project Announcements forum???
thanks
dweebs0r
  • Ascendo tuum!
You could keep the buttons in the front, for credits and pinball flippers.
I agree though that there is no way I would enjoy playing an arcade game with those.
-Dweebs
« Last Edit: July 11, 2005, 09:26:14 am by dweebs0r »
eggedd2k
Re: Pics of my new cab - any suggestions for changed/upgrades?
« Reply #5 on: July 11, 2005, 08:45:02 am »
i'll have to measure the hole diameter of the buttons. i know for sure that they're smaller than standard buttons.
Franco
« Reply #6 on: July 11, 2005, 10:43:49 am »
Any reason you dont want to drill bigger holes? Is it because you want to keep the CP as it was originally made or maybe you dont want to risk messing it up if you dont feel up to the job?
It looks to me like the top of the control panel screws off. I would suggest making a new panel with propper buttons to replace it. That way it will be easier to make from scratch rather than trying to open the original holes out, and you will also be preserving the original CP and you will always be able to put it back.
eggedd2k
« Reply #7 on: July 11, 2005, 10:51:09 am »
yeh the reason i didnt want to drill the existing one was to preserve it plus i'd be too concerned of messing it up.
you reckon replacing it with a new one would be a good idea?
Goz
  • KOTA
« Reply #8 on: July 11, 2005, 11:01:34 am »
Start measuring and hope that they aren't too odd. If you are lucky they may be able to be replaced with the 24mm or 30m buttons made by Sanwa.
-Goz
eggedd2k
« Reply #9 on: July 11, 2005, 11:29:24 am »
presumably it's just the hole diameter i need to measure?
the only concern i've got with replacing the control panel is the bit indicated with the arrow on the image below. that part is angled (45 degrees?) the wood and the plexiglass overlay.
if i'm lucky i'll be able to get some replacement buttons.
i'll have a measure up and post the measurements.
JamIt
  • Last login:June 17, 2011, 03:27:07 pm
eggedd2k
« Reply #11 on: July 11, 2005, 12:01:52 pm »
 ;D i was gonna make a cabinet from scratch but when i found out i could buy a fully working jamma cab for
eggedd2k
« Reply #12 on: July 11, 2005, 12:03:21 pm »
forget putting in a new control panel - the colours wouldnt match and it'd look naff. buttons deffinitely need replacing though.
eggedd2k
« Reply #13 on: July 11, 2005, 01:33:05 pm »
just measured the buttons - they're 24mm.
can you get 24mm buttons? I'll put a post in the bst forum see if anyone's got any
Goz
  • KOTA
« Reply #14 on: July 11, 2005, 02:04:51 pm »
I posted a response in the BST thread. Basically the answer is Yes, but I've only seen them in the Sanwa style. You can get these from HIMURA Games or RichardP71 from here was selling some a couple of weeks ago.
I included pics of the 24mm buttons in the other thread.
Hope this helps.
-Goz
eggedd2k
« Reply #15 on: July 11, 2005, 02:15:25 pm »
thanks goz. if i could get some from here in the uk i'd be sorted.  would those two send to the uk?
Mr-Megalo
  • Last login:July 13, 2006, 08:36:28 am
  • Piano fingered Capcom Addict
« Reply #16 on: July 12, 2005, 02:01:24 pm »
yes both richard & himura would send buttons to the UK, they are the ones I have.
you would be best measuring the holes without the buttons in place
eggedd2k
« Reply #17 on: July 12, 2005, 03:54:44 pm »
yeah i did that - the holes (without buttons) 24mm in diameter
Mr-Megalo
« Reply #18 on: July 12, 2005, 04:25:40 pm »
in that case then you shouldnt have any problems, might be wiser to get "screw in" buttons rather than "snap in" buttons - UK cabs & the thickness of the CP could cause problems with how some buttons fit
I've dealt with Richardp171 and himura and can highly reccomend them both
