Author Topic: Keywiz Problems  (Read 1855 times)
testicle187
  • Last login:April 10, 2025, 05:29:07 pm
Keywiz Problems
« on: July 11, 2005, 12:52:30 am »
I use a Keywiz Max and I have some startup problems with it.  I need my computer (running Windows XP) to boot the Keywiz program and then load Mamewah on exit.  I have the shortcut made as C:\keywiz.exe -A  and that is working correctly, but if I also have Ultrastyle or Mamewah in my startup group it causes problems when they load together IE. the encoder doesnt get programmed  and Mamewah moves around a little and picks a game on it's own.
Is there some command line way to set my Keywiz Uploader software to run it's course and then start MameWah on bootup?  I jsut can't figure this out.
Tiger-Heli
    • Tiger-Heli
Re: Keywiz Problems
« Reply #1 on: July 11, 2005, 09:30:39 am »
Open Notepad:
Type in:
C:\keywiz.exe -A
C:\MAMEwah.exe
(or whereever MAMEwah is).
Save as KeyWiz.bat.
Create a shortcut to KeyWiz.bat.
Place shortcut in Startup group and delete other shortcuts.
If this doesn't work, you could use a program like BatchRun to specify that MAMEwah shouldn't start until the KeyWiz software exits.
testicle187
Re: Keywiz Problems
« Reply #2 on: July 11, 2005, 03:34:22 pm »
You are a god Tiger-Heli!  It loads up in the correct order and functions perfectly like that.
Tiger-Heli
    • Tiger-Heli
Re: Keywiz Problems
« Reply #3 on: July 11, 2005, 04:08:54 pm »
There are a few advantages to having used computers before Windows 3.1 (mainly that you appreciate what you don't have to do anymore.)
Stobe
  • Trade Count: (+17)
Re: Keywiz Problems
« Reply #4 on: July 11, 2005, 04:26:24 pm »
To make it more authentic, you should drop to dos and use the EDLIN command to create that batch file. :)
-Stobe
(I could type so much faster before Windows came about)
