Author Topic: USB Dual Strike Hack  (Read 2262 times)
wee beastie
  • Last login:October 06, 2003, 03:33:02 pm
« on: December 20, 2002, 03:23:38 pm »
So, I'm trying to do 1UP's dual strike hack with my Star Wars yoke.  On the yoke, one of the pots is broken, so I ran down to radio shack and started looking at the pots.
As is my understanding, I need a 5K, 3/4 turn pot.  The only 5K pot I saw was a 300 degree turn pot.  Will this work?
tia,
wee
« Last Edit: December 20, 2002, 03:24:44 pm by wee beastie »
JustMichael
  • Mmmmm!! Cheesecake!!
Re:USB Dual Strike Hack
« Reply #1 on: December 20, 2002, 07:58:13 pm »
well 3/4 turn is 270 degrees.  It sounds like it would be close enough as long as it is physically the right size.
wee beastie
« Reply #2 on: December 20, 2002, 08:51:18 pm »
yeah, I'd just hate to have to take it apart to get it to work properly.  I suppose that the dual strike comes with some sort of internal calibration tool, right?  If so, could you calibrate it to give the full range of motion even if the pot doesn't turn it's fullest?
Lilwolf
« Reply #3 on: December 21, 2002, 03:21:34 am »
Probably not for long.  RS doesn't sell parts made for those type of loads... But try it and hope for the best.... btw, happs sells them, so you will probably find them at BobRoberts and www.videoconnect.com
1UP
  • Token Junkie
    • 1UPArcade
« Reply #4 on: December 21, 2002, 03:57:06 am »
The only load that it'll be getting is from the Dual Strike electronics, it's not going into a jamma cab or anything.  But might as well get the proper pots if you can find them.  I saw some 5k pots at Fry's before.  Actually, they can probably even be 10k pots.  Anyway, the Midway T2 manual specifies that 10k pots are acceptable as replacements for 5k's in the T2 guns, so might still work...  The ones you found would still be closer though...
My other job...
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #5 on: December 21, 2002, 10:31:28 am »
I'm guessing lilwolf meant the mechanical load of constant movement of frantically shooting down TIE's being too much for radio shack pots...  and that they'd mechaniclly break...
rampy
