Author Topic: Need help w/ small server  (Read 1171 times)
USSEnterprise
  • Last login:October 11, 2007, 11:15:08 pm
    • USS Odyssey
« on: July 08, 2005, 05:18:23 pm »
I'm setting up a small web server for an RPG I'm settin' up. I'm not using Microsoft software because too expensive. I plan on using Linux and Apache Web Server. Can anyone recommend a distro of Linux that would be good for this? I am limited to a 4.3GB HDD for the system drive.
Proper capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: Need help w/ small server
« Reply #1 on: July 08, 2005, 08:16:52 pm »
What are you going to DO with the server ? (e.g. what does the server have to do with the RPG, what services are you planning to run, etc.)
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
Sephroth57
  • Poo Monkey
  • Last login:June 07, 2020, 11:17:00 am
    • Check it out!!!
« Reply #2 on: July 09, 2005, 01:13:08 am »
sounds like a MUD im assuming?
"Owens is the ringleader in the ass hat circus"  D K
D10
  • Last login:April 08, 2022, 12:44:44 pm
  • Pull my finger
« Reply #3 on: July 09, 2005, 01:27:08 am »
Any distro would work. Just use which ever you are comfortable/familiar with. If you are going to tbe just serving pages for a small site you should be fine, but if you want to store user info in a database and such you might want to get more drive space.
USSEnterprise
    • USS Odyssey
« Reply #4 on: July 09, 2005, 01:29:20 am »
MUD?
I plan on hosting both a small website and a message board. I am going to throw another hard disk in there for data storage, since the OS will likely take up most of the drive. The computer I'm using is a 366MHz Celery with 192MB RAM
Sephroth57
  • Poo Monkey
    • Check it out!!!
« Reply #5 on: July 09, 2005, 01:34:52 am »
MUD, multi user dungeon, text RPG... guess not. its pretty oldschool
D10
  • Pull my finger
« Reply #6 on: July 09, 2005, 01:35:38 am »
Stands for Multi user dungeon a text based RPG.
Oops beat me to it
USSEnterprise
    • USS Odyssey
« Reply #7 on: July 09, 2005, 02:21:37 am »
Well, it will essentially be text based, except for some pics on the web site and ranks pictures on the boards.
USSEnterprise
    • USS Odyssey
« Reply #8 on: July 09, 2005, 02:25:20 am »
If worse comes to worse, I'll link to an invisionfree forum
USSEnterprise
    • USS Odyssey
« Reply #9 on: July 09, 2005, 10:21:30 pm »
Right now, I'm trying to install Slackware. I've heard its very versitile
