Author Topic: MameWah Woes - Solved  (Read 1401 times)
starnix17
  • Last login:December 19, 2011, 11:00:29 am
« on: July 08, 2005, 12:34:47 pm »
Ok... I've been trying to hook up MameWah and it doesn't want to launch my games. When I generate the list it finds them fine, but it won't launch them (a command prompt window just pops up for a few seconds). I can open up a command prompt and run the games fine.
Here's my mame.ini file (well... the parts that you would need to see):
Code: [Select]
### mame.ini (mamewah v1.61) ###
emulator_title                            M.A.M.E.
### List Generation Settings ###
rom_path                                  c:\roms
rom_extension                             zip
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder_vs_listxml
### Execution Settings ###
emulator_executable                       c:\mame\mame.exe
commandline_format                        [name] {autodosbox} {nosafelaunch}
alt_commandline_format_1                  [name] {autodosbox} .\{nosafelaunch}
alt_commandline_format_2                  [name] .\{autodosbox} .\{nosafelaunch}
game_specific_config_path
And here's what I find in the MameWah log file:
Code: [Select]
7/8/2005 12:28:35 PM Desktop colour: 10841658
7/8/2005 12:28:35 PM Wallpaper filename:
7/8/2005 12:28:35 PM Display mode: 1024x768 @ 60Hz, 16 bit colour
7/8/2005 12:28:35 PM Decimal symbol: '.'
7/8/2005 12:28:35 PM Games list read: mame-0.lst
7/8/2005 12:28:36 PM Layout selected: C:\Documents and Settings\Administrator\Desktop\mamewah_v161\layouts\Classic 640x480\layout.lay
7/8/2005 12:28:37 PM Ctrlr file selected: C:\Documents and Settings\Administrator\Desktop\mamewah_v161\ctrlr\default.ini
7/8/2005 12:28:48 PM Commandline run: CMD.EXE /c c:\mame\mame.exe DKONG -verifyroms > C:\DOCUME~1\ADMINI~1\Desktop\MAMEWA~1\files\verify {flags=17}
7/8/2005 12:28:50 PM Commandline run: c:\mame\mame.exe DKONG   {flags=12}
7/8/2005 12:29:39 PM MAMEWAH quit
« Last Edit: July 09, 2005, 08:40:59 pm by starnix17 »
ahmer
  • Last login:March 16, 2014, 02:40:21 pm
  • Do as you like.
    • IC Markets Rebates and Discount
Re: MameWah Woes
« Reply #1 on: July 08, 2005, 08:15:47 pm »
May be ur missing something.
Do you have installed mamewah system files?
Check for Directx,does it works correctly?
Just put all ur Mame and Mamewah stuff in a single folder, like
c:\mame
delete all the INI files from INI folder and regenerate the gamelist.
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
Re: MameWah Woes
« Reply #2 on: July 09, 2005, 12:26:23 am »
I really don't have a clue, but could it be that your orientation is wrong for mame in use of mamewah?
1024x768 doesn't work well in my mamewah setup.  Everything I have is 800x600.
Trust me, I know I sound like an idiot on this one, just throwing out an idea.
NinjaEpisode
  • Last login:June 16, 2019, 06:47:45 pm
Re: MameWah Woes
« Reply #3 on: July 09, 2005, 06:39:48 pm »
Your ini file looks wrong.
It doesn't look like you have the path to your roms:
emulator_executable                       c:\mame32\mame.exe
commandline_format                        "[rompath]\[name].[romext]"{autodosbox}{nosafelaunch}
« Last Edit: July 09, 2005, 06:46:03 pm by NinjaEpisode »
starnix17
Re: MameWah Woes
« Reply #4 on: July 09, 2005, 08:40:20 pm »
Yup.... that was it! Thanks a lot for the help  :D.
