Author Topic: My First MAME project (updated)  (Read 5454 times)
USSEnterprise
  • Last login:October 11, 2007, 11:15:08 pm
    • USS Odyssey
« on: July 05, 2005, 02:40:35 am »
While watching an ep of the Twilight Zone, I drafted these designs. They are not totally to scale, but they're damn close. As of now, I have very little cash so it may not be built for a while.
« Last Edit: August 08, 2005, 03:20:25 pm by USSEnterprise »
Proper capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse.
USSEnterprise
    • USS Odyssey
Re: My First MAME project
« Reply #1 on: July 05, 2005, 02:15:07 pm »
I'm going to lumber yard either today or tomorrow so I can start construction. Going to get 1/4 inch ply sheets and a 15/32 sheet to support the monitor, which is around 85lbs.
Franco
« Reply #2 on: July 05, 2005, 03:17:04 pm »
If you use 1/4 in ply sheets your cab is likely to blow over!
USSEnterprise
    • USS Odyssey
« Reply #3 on: July 05, 2005, 04:16:38 pm »
ok, you are probably right. I will use 3/4 for the sides and shelf and base. Now all I need is more cash.
USSEnterprise
    • USS Odyssey
« Reply #4 on: July 10, 2005, 10:47:53 pm »
Yay! I got a loan from my Dad. He says since he will get use out of the machine too, he'll loan me some money. I can start work.
krion
  • Last login:January 13, 2021, 01:18:20 pm
« Reply #5 on: July 11, 2005, 08:29:08 am »
awesome,
cant wait to see some pictures!
dema
  • Last login:September 02, 2014, 03:05:34 am
« Reply #6 on: July 11, 2005, 04:26:52 pm »
Make sure you build in more support beneath the control panel. It will be taking some abuse during play and you'll want to make sure you have it secure.
tommy
« Reply #7 on: July 11, 2005, 09:49:43 pm »
I have a bunch of card board for making your cab if you really want to save some cash.  ;D
USSEnterprise
    • USS Odyssey
« Reply #8 on: July 13, 2005, 02:40:52 am »
I am going to star buying stuff on the weekend. Already have a joystick and 9 buttons, and 2 trackballs from ebay, one of which I will resell.
USSEnterprise
    • USS Odyssey
« Reply #9 on: July 19, 2005, 01:15:03 am »
I just got 3 sheets of (very heavy) MDF for the side panels and other panels. I got a trackball I'm gonna use, and buttons and joysticks. Going to start planning and cutting of the side panels tomorrow. What is the best way to cut them so they are identical? I was planning on cutting them at the same time, one ot top of another.
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #10 on: July 19, 2005, 03:07:25 am »
Use clamps if you've got em to hold the two pieces together.
USSEnterprise
    • USS Odyssey
« Reply #11 on: July 19, 2005, 03:13:53 am »
Yeah, I was planning to use a few c-clamps. I just wanted to know if I was going about it correctly by cutting them at the same time.
tommy
« Reply #12 on: July 19, 2005, 07:56:25 am »
If your jigsaw you and the blade are up to it cut them togeather, that way they will/should be exactly the same.
USSEnterprise
    • USS Odyssey
« Reply #13 on: July 19, 2005, 11:46:36 pm »
MDF is chalklined with side panel design and waiting to be cut. Pictures soon
AlanS17
    • AlanS17
« Reply #14 on: July 21, 2005, 12:26:26 am »
I hope it's not too late to warn you. Unless it's industrial strength, you're gonna burn up a jigsaw (or 2) by trying to cut through both at the same time. Jigsaws don't handle 1.5" very well. And you're going to be very dissapointed with the curves if you don't go crazy slow. The blade will move even though you're holding the blade in place. I recommend making as many cuts as possible with a circular saw and cutting the corners VERY slowly with the jigsaw. If you have to question your speed you're probably going too fast.
USSEnterprise
    • USS Odyssey
« Reply #15 on: July 21, 2005, 12:34:01 am »
yeah, I might go with a circular saw for most of the cutting. Its a very angled cab design, so the circular saw should work well for most of it. I only have a Ryobi jigsaw, so I won't chance it.
USSEnterprise
    • USS Odyssey
Re: My First MAME project (updated)
« Reply #16 on: August 08, 2005, 03:22:59 pm »
I've got the main part of the cab built. Got most of the computer equipment. Will have to use an LCD monitor due to depth restrictions. Many buttons in the mail. The marquee exists as a Photoshop file on my PC. I will upload pictures soon, but I'm on dial-up right now
USSEnterprise
    • USS Odyssey
« Reply #17 on: March 04, 2007, 04:47:31 pm »
For over one and a half years, my cab has sat empty in my parents living room. Not they say to throw it out or finish. I choose the latter. Within a month or two, it shall be finished! All major construction is done. My father, to help me along, is buying an LCD for me to use, and is going to help engineer a motorized rotation system based on many of the ones I have seen here. Controls will incluse two red Omnistick-basics, sixteen red pushbuttons (and 2 players), one BI 3" trackball, and one arkanoid spinner. Will be utilizing a Keywiz Max and Opti-Wiz for controls. For the PC, I am going to be using an old 733MHz Celeron HP with 192MB RAM. I need to dig up my old marquee and see if it still applies to my planned color scheme. This will take time, but I can't wait until I'm finished.
