Author Topic: V2 Spinner rattle...  (Read 1602 times)
Elfman
  • Last login:February 01, 2012, 05:58:11 pm
  • Cabinet done! CP Done! Just tweaks left to do.
    • My Corner of the World
« on: July 04, 2005, 10:54:22 pm »
I got my control panel finished and got all the parts of my CP done (See Here).
Gamecab
  • Last login:March 06, 2008, 05:34:27 pm
  • Flight Yokes - 9/10/05
    • GameCab
Re: V2 Spinner rattle...
« Reply #1 on: July 04, 2005, 11:28:30 pm »
I had the same problem with my Vortex about 6 months ago and I contacted Kelsey about it.  Kelsey gave me a very simple solution for this and since then the problem has not come back.
Solution - Go to the hardware store and pick up a small bottle of 3 in 1 oil.  (It has to be 3 in 1 and not WD40 because the 3 in 1 will clean out any bits of sawdust that may be trapped in the nylon bearing).  Remove your Spinner knob and put 3 drops between the blue nylon bearing and the steel shaft, do the same for the bottom bearing.  Now give it a spin and I bet its as good as new again.
The Brrrrr Brrrr Brrrr noise on your MPEG was exactly what my spinner sounded like.
Charlie
The Flight Yoke Release date is September 10, 2005.
toolaa
  • Last login:April 04, 2024, 02:03:09 pm
  • Work In Progress...
    • Moon Patrol Project
« Reply #2 on: July 04, 2005, 11:31:05 pm »
My V2 does the same thing, but it does not sound as bad as yours.
Super Sprint - In Progress ($150)
Moon Patrol MAME - Completed ($670)
Tic-Tac-Strike Puck Bowler - Restored ($1200)
First Time Visitors Say "Holy Cow!"
. . . . . .Priceless
Elfman
« Reply #3 on: July 05, 2005, 09:22:25 am »
Cool.
Thanks for for the input.  I'll pick some 3 and 1 up today and hit those bearings.
Thanks again.
Hoagie_one
  • Um....whats a cabinet
« Reply #4 on: July 05, 2005, 10:29:21 am »
had me worried.  I was hoping that I hadn't sold you a bumm product.  I never even used it.  Just bought it, tested it, and boxed it up.
Elfman
« Reply #5 on: July 05, 2005, 12:48:17 pm »
Elfman
« Reply #6 on: August 23, 2005, 01:12:20 pm »
Just in case anyone else has had this problem, Charlies solution fixed my rattling immediately.  The 3 in 1 oil worked great!
Thanks again!
Scoobie
  • Last login:December 26, 2024, 12:53:48 am
« Reply #7 on: August 23, 2005, 03:54:42 pm »
Would sewing machine oil work as well?
johnk
  • Last login:January 17, 2019, 04:29:50 pm
« Reply #8 on: January 03, 2006, 01:48:28 pm »
Thanks very much!!!  This fixed the vibration on two of my spinners.
I used "Needle-Tip Precision Oiler" from Radio Shack ($3), part # 64-2301A.  It says it will last almost indefinitely.
