Author Topic: LED Sources / Suggestions  (Read 3840 times)
Franco
« on: July 04, 2005, 02:19:12 am »
Hopefully I should have some of Shawnzillas clear buttons winging there way to me  :)
Eventually I want to light them in conjunction with Buddabings LED driver board but I think it may be a while until this is avaliable. Im thinking of using four leg tri-colour LEDs with them in the end but I would like to light the clears whilst I am waiting for the board.
I am presuming that one of the four legs on the LED is the ground and the other three are for each colour? Would it be possible for me to just light the buttons using one colour leg and the ground in the meantime?
If this is possible does anyone know of any good sources for tri-colours?
Franco
Re: LED Sources / Suggestions
« Reply #1 on: July 04, 2005, 08:30:13 am »
I have been having a bit of look arond and it looks like you can only get three leg tri-colour LEDs with one of the legs being the common annode and the other legs giving you the single/mix of colours. I want my buttons to be lit blue at the moment and I wont be able to do this just using the tri's without the driver board.
I think im just gonna go for some normal blue LEDs for the moment.
Ive seen these on eBay:-
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=14984&item=7334334525&rd=1
Do you think they will be bright enough/too bright? They are rated at 7000mcd.
They are also available in 3mm and 5mm for the same price. Is one size more suitable than the other?
Thanks.
Buddabing
« Reply #2 on: July 04, 2005, 10:48:20 am »
Please read the wiki!
Franco
« Reply #3 on: July 04, 2005, 12:02:46 pm »
Thanks for the info Buddabing.
Did you go for the clear or diffused Tri-colours? I imagine the diffused would be better to spread the light more evenly in the button.
Any more news on the boards?
rdagger
« Reply #4 on: July 04, 2005, 12:40:44 pm »
I also bought RGB LED's from Super Bright LEDs for my driver board.  I'd recommend getting the diffused lens because they will illuminate the buttons more evenly.  Also becareful when soldering because the leads are very close together.
« Last Edit: September 02, 2006, 01:31:17 pm by rdagger »
Buddabing
« Reply #5 on: July 04, 2005, 12:43:50 pm »
IIRC I went for the diffused, but I don't remember for sure.
I've got a working prototype all wired up and working. GameCab is working on getting sources for all the various parts. Once that is done, we'll be able to set pricing and take orders for boards.
I am working fast and furious on the software.
Franco
« Reply #6 on: July 04, 2005, 12:58:26 pm »
Are we looking at the same page?
 http://www.superbrightleds.com/cgi-bin/store/commerce.cgi?product=LEDS
The diffused ones on that page are only avaiiable with a common cathode and I need a common annode right?
Good work on the board Buddabing, cant wait!
rdagger
« Reply #7 on: July 04, 2005, 01:20:35 pm »
Here is what I used:
Product:       RL5-RGB-D TriColor LED $ 1.95 (each)
Options:       Common Cathode
I wanted a common ground.
Buddabing
« Reply #8 on: July 04, 2005, 05:11:10 pm »
I ordered these:
Product:       RL5-RGB-C TriColor LED $ 1.59 (each)
Options:       Common Anode
Unfortunately, they don't come in a frosted/diffused variety.
CJK
  • Last login:February 03, 2024, 03:30:12 am
  • All your ROM are belong to us!
« Reply #9 on: July 04, 2005, 05:24:01 pm »
Looking forward to placing my order!   ;D
-- Chris
Underway: Joey's Arcade
crashwg
« Reply #10 on: July 05, 2005, 12:15:55 am »
Is there any particular reason you went with common anode Budda?  I though common cathode was more the "norm"...  :-\  I could be wrong on that, it's just my observation.
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
Buddabing
« Reply #11 on: July 05, 2005, 11:41:33 am »
rdagger
« Reply #12 on: July 05, 2005, 12:16:37 pm »
I wonder about the relative brightness of the red, green, and blue LEDs, what colors will be possible, and how hard it will be to produce white.
Using pulse width modulation you can create just about any color.  You can get the relative RGB brightness even by playing with the resistors, but it does take a little work.  Furthermore, I found that the RGB LED's don't have consistent brightness.  Therefore, the resistor combination that works for one LED may not be ideal for the next.   The diffused lens makes a big difference when working with the RGB LED's.  Although the clear lens is brighter, it does not mix the 3 colors well.  Therefore, when you start mixing the RGB colors, you can see hot spots of the primary colors though the clear lens.
Here's a shot showing one my pushbuttons illuminated with a diffused RGB LED cycling through a few colors:
gl.tter
  • Last login:October 10, 2009, 04:53:44 pm
« Reply #13 on: July 05, 2005, 02:14:59 pm »
There seems to be conflicting information on LED terminology.
« Last Edit: July 05, 2005, 02:18:14 pm by gl.tter »
author of the Quake2 and Half Life Act Labs lightgun conversions:
Buddabing
« Reply #14 on: July 05, 2005, 02:25:00 pm »
gl.tter
« Reply #15 on: July 05, 2005, 02:33:14 pm »
I do not support pulse width modulation, so only 4913 (17*17*17) colors are theoretically possible on my controller with the RGB LEDs. I don't know how many it'll actually be in practice, I'll have to do some experimenting.
Actually your controller chip is most likely using PWM (pulse width modulation) behind-the-scenes.
Franco
« Reply #16 on: July 06, 2005, 02:24:45 am »
Just had a thought.
Buddabing, your largest LED will have 40 outputs, correct?
I imagine we will not be able to control 40 RGB LEDs independantly as I would imagine each of the three colour legs would need to be conected to an output?
If this is the case will we only be able to run thirteen independant RGBs of the board?
I wanted to run around 16 RGBs independantly and 16 normal LEDs independantly as well. Please say this will be possible!
If we cannot control them all of one board will it be possible to link two?
Buddabing
« Reply #17 on: July 06, 2005, 10:13:48 am »
Just had a thought.
The board will be able to control 40 outputs. Since the RGB LEDs each take three outputs, the board will only control 13 RGB LEDs.
It will be possible to link two boards. However, this will require a slight reversible mod to the second board. One leg of two of the ICs on the second board will have to be lifted and a jumper wire soldered from the lifted leg to one of the other legs. To split the parallel port signal, you can use a parallel port splitter cable like I am using for debugging, or you can run two jumper wires from the first board to the second.
Are you serious about getting two boards? It will require some software changes on my part.
Franco
« Reply #18 on: July 06, 2005, 11:19:50 am »
Yeah in that case im going to need at least 64 outputs if possible, so ill probably be looking at two 40 boards This is depending on price of course, and ideas about how much we are going to be talking? I know you probably havent figured costs out but a ball park figure would be nice before I get all excited and buy a load of LEDs etc.
Will the software changes be a big hassle for you?
Buddabing
« Reply #19 on: July 06, 2005, 12:40:32 pm »
The software changes are already done.
The software changes mostly involved changing the number 40 to the number 80.
I did have to create a config option to enable the second controller.
So it was no big deal.
I'm sorry, I cannot give you specific details about pricing at this time. I have committed in another thread to providing a fully loaded 40 LED controller with wired-up white LEDs, power cable, and parallel port cable for less than $100. I will honor that commitment. If you want to buy your own LEDs and wire them, then the cost will be less.
Don't worry, you will know the pricing before you order. :)
g1275
  • Last login:June 19, 2008, 11:50:17 pm
« Reply #20 on: July 06, 2005, 03:39:28 pm »
With the RGB LEDs is there anyway to keep it constant on one color, say purple, instead of cycling through the diferent colors. I was thinking of utilizing this to have each player choose the color of buttons and joysticks that they want.
Is this possible?
Buddabing
« Reply #21 on: July 06, 2005, 03:50:46 pm »
Is this possible?
Sure. I am working on making a way to specify colors so that you can have purple LEDs for pacman, green for Donkey Kong, etc.
What you describe might be more useful in a front end application, but it is doable.
g1275
« Reply #22 on: July 06, 2005, 03:54:43 pm »
I know certain RGB LEDs have different timings, like 2 or 10 seconds between color changes, would it make a difference which one you get and where you got it from?
Buddabing
« Reply #23 on: July 06, 2005, 04:00:04 pm »
I don't know if it would make a difference or not. I was unaware of any LEDs that take so long to switch color. Do you have a part number or something I can look at?
g1275
« Reply #24 on: July 06, 2005, 04:21:50 pm »
On Superbrightleds.com they have the RL5-RGB-C TriColor LED which doesn't appear to change colors automatically. But on Ebay they have all types of RGB LEDs and Tricolor LEDs that are automatically changing. For example
Tri-colour LEDs are again two LEDs, but this time with 3 legs (common anode or cathode).
« Last Edit: July 06, 2005, 04:32:21 pm by g1275 »
gl.tter
« Reply #25 on: July 06, 2005, 07:06:18 pm »
If you want to control the colour yourself, you don't want colour-changing ones.
