Author Topic: How to disable Scandisk in XP.  (Read 1527 times)
ahmer
  • Last login:March 16, 2014, 02:40:21 pm
  • Do as you like.
    • IC Markets Rebates and Discount
« on: July 03, 2005, 06:16:51 pm »
I am using mamewah as my windows Xp shell,i don't know how can
i disable scandisk,as every time it automatically starts after bad shutdown.
darktemp
  • Last login:July 20, 2006, 11:18:39 pm
  • Rumbler
Re: How to disable Scandisk in XP.
« Reply #1 on: July 03, 2005, 06:20:00 pm »
You need to use NTFS as your file system instead of FAT32.
ahmer
  • Do as you like.
« Reply #2 on: July 03, 2005, 06:27:54 pm »
Do you meand that ? Instead of Fat32 if i make NTFS partition for xp then scandisk will never run in the beginning.
for using mame and mamewah does NTFS partition makes any difference?
darktemp
  • Rumbler
« Reply #3 on: July 03, 2005, 06:32:58 pm »
NTFS won't make any difference as far as mame or mamewah.  You will never notice any difference except NTFS basically runs it's version of scandisk behind the scenes so you will never notice it's happening.  Basically NTFS is a newer more efficient file system so if your using win2k or xp and don't dual boot with win98 you should be using NTFS imo.
Edit:  That's correct, scandisk will never run at startup if you switch.
ahmer
  • Do as you like.
« Reply #4 on: July 03, 2005, 06:53:12 pm »
thanks tarktemp.
Actually i already make my D: drive as NTFS partition for XP but i did not note it before that NTFS has this great feature.
USSEnterprise
  • Last login:October 11, 2007, 11:15:08 pm
    • USS Odyssey
« Reply #5 on: July 03, 2005, 07:49:37 pm »
But wont he have to format his HDD just to make the change?
Proper capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse.
jcrouse
    • CPViewer
« Reply #6 on: July 03, 2005, 10:11:57 pm »
No. There is a Convert to NTFS utility that is part of the OS. That being said, I would try and find a way to rewire your cabinet for a graceful (proper) shutdown. There are many threads here that explain multiple ways of accomplishing this.
John
