Author Topic: How many pins....  (Read 2112 times)
gajaman
  • Last login:July 19, 2011, 02:50:33 pm
  • The GajaCab is here......
    • The Gaja Project
How many pins....
« on: May 03, 2002, 07:02:36 am »
...does the ATI all-in-wonder 128 have on the s-video connector? My laptop mobility card has 7 (making it hard to get  a lead), but my sister's geforce card has 4, using a standard lead.
If you have one can you look at the pins and let me know - muchos gracias amigos.
JMDickson
  • Last login:October 21, 2011, 11:22:48 pm
Re: How many pins....
« Reply #1 on: May 03, 2002, 07:46:08 am »
It also has 7 pins, but... it accepts a standard s-video cable.  It is designed to put a standard s-vid signal on the outer 4 pins.  If you wanted composite video, then you would need a special lead to tap the inner pins (pin 2).
aramis
  • Last login:November 26, 2002, 09:24:04 pm
  • mame cab ALMOST done!
« Reply #2 on: May 03, 2002, 09:01:04 am »
my ATI AIW128 came with ta short little "break-out cable". One end plugs to the card, and the cable y's to leads for composite video and S-Video. (May also be a third plug, I can't remember right now...).
My point is that the special cable should have been included w/ the AIW128...
