Author Topic: CHD relocation  (Read 1740 times)
peanut
  • Last login:November 11, 2009, 01:47:29 pm
  • arcade nut
CHD relocation
« on: June 30, 2005, 02:00:09 am »
Hi all, im looking for a way to put my CHD files in a different directory than my roms folder. RIght now i have a 20gig HD which is almost full due to regular mame and all the roms, and i just dled the CHDs which is 28 gigs and id like to put them all on my blank 30gig HD i have installed. Is it possible to specify a directory to point mame to the CHDS?
Acids
  • Last login:July 26, 2025, 06:10:07 am
  • Bring It.. Smart arse!
Re: CHD relocation
« Reply #1 on: June 30, 2005, 04:44:42 am »
The short answer is YES.
The full answer requires you to tell us what version of mame you are using?
SirPeale
  • Green Mountain Man
Re: CHD relocation
« Reply #2 on: June 30, 2005, 07:09:28 am »
It does?  I thought he'd just specify the location in mame.ini (or mame.cfg for DOS or mame32.ini for Mame32, etc)
ie:
rompath  G:\mame90\tps;G:\mame90\maxaflex;G:\mame90\ar_bios;C:\CHD;
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re: CHD relocation
« Reply #3 on: June 30, 2005, 09:32:47 am »
Peale is right, it doesn't matter which version, just setup the rompaths.
BTW, this is why I instantly don't like any FE that can not handle multiple rom paths, because mame can.
  • Last login:Yesterday at 07:46:44 pm
Re: CHD relocation
« Reply #4 on: June 30, 2005, 02:12:58 pm »
Actually.... it does matter which version of mame you are using.  Earlier compiles of mame didn't handle chds very well and you had to keep a copy of the rom uncompressed in the same folder as the chd.  Now this is no longer the case and as you both said, you simply setup the paths.  If using an older version, however, do what I just said.  :)
peanut
  • arcade nut
Re: CHD relocation
« Reply #5 on: June 30, 2005, 03:06:12 pm »
Im using mamewah, does that handle multiple paths?
