Author Topic: arcados picture is too small please help  (Read 2291 times)
bruce
  • Last login:December 12, 2002, 09:41:18 pm
« on: December 17, 2002, 03:19:09 am »
okei i got the picture to display the wg 19", also i got the picture to stay but it so small, when arcadeos appear it seems to fill up the screen but when the game (mslug is the game i'm testing out) start to run  the picture is small  ???.  Any one know to stretch it out.  it looked like you run low resolution with setting of high resolution.  Anyone know to get this fix?
also i did try the vertical size knobs.
Superdude
  • Last login:January 22, 2016, 11:53:48 am
  • Mo' Betta Butter with da Betta Playa'
Re:arcados picture is too small please help
« Reply #1 on: December 17, 2002, 12:14:11 pm »
Look in mame.cfg
Look for hardware stretch.
Set it to yes or 1.
Problem should be fixed.
bruce
« Reply #2 on: December 17, 2002, 11:24:21 pm »
when i opened the mame.cfg with notepad, the file look all messed up,couldn't see any letters they're all in weird format. Any ideas why is that? i rezipped mame again to but still can't see letter when i tried with notepad or wordpad.
anyone have the solution to this.  Thanks
Bruce
mattv
  • Last login:June 10, 2022, 06:33:25 am
« Reply #3 on: December 19, 2002, 01:11:44 am »
I had this problem with vert games on a horizontal monitor using arcadeOS. switching to advance mame fixed this (and several other minor but annoying problems)
bruce
« Reply #4 on: December 19, 2002, 11:40:58 pm »
i still use arcade os, but enable stretch for the game and that fix it.  Still the video seems to miss green colors, because pictures seems to be pink as the result of dominant of red and blue colors.  Does anyone know how to fix this? i resolder the green wire but still doesn't work.  i wonder if the solder on blue and red is not good would that cause these colors to dominant the green.
