Author Topic: MaLa - #1 Vertical FE  (Read 16077 times)
loadman
  • Moderator
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
« on: June 24, 2005, 09:03:18 pm »
« Last Edit: August 05, 2005, 08:37:36 pm by loadman »
toyfiend2004
  • Last login:May 12, 2007, 09:07:04 pm
  • Like... where do you put the quarters, dude?
Re: MaLa - #1 Vertical FE
« Reply #1 on: June 28, 2005, 11:50:25 am »
WOW!! now this one is not one i recommend.  unless, that is you can read german.  all of the pop-up and error boxes come up in german.  I had to keep going to an freetranslations.com to convert what it was saying over to English.  In theory, it was a hopeful in order to easily incorporate multiple emulators st be really simple as I am a noobie to this FE stuff and am not familiar wih codes, etc.  I need an easy one.
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #2 on: June 28, 2005, 04:47:35 pm »
Just from glancing, it doesn't support 321x240 resolution for arcade vga owners, (And I can't stand my front end to be interlaced)
Later,
dabone
loadman
  • Moderator
    • MaLa
« Reply #3 on: June 29, 2005, 05:28:10 am »
« Last Edit: June 29, 2005, 05:29:56 am by loadman »
toyfiend2004
« Reply #4 on: June 29, 2005, 11:29:38 am »
i could read everything in english except fot the error messages.  I had no clue what I was doing wrong when one of them popped up.  Everything else was in English. :P
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #5 on: June 29, 2005, 11:40:08 am »
I don't know Mame Launcher.
But if you are looking for a FE which can work in Vertical as well than horizontal or coktail and support all Resolution of the Arcade VGA , you can try mine.  www.atomicfe.com
I promess you ... Error message won't be in German!...  ;)  (hum..what about french?  ;D)
toyfiend2004
« Reply #6 on: June 29, 2005, 01:37:44 pm »
I tired your FE.  It was okay, but as I am not very intelligetn in this field yet, I was not able to get it to load my mame, and multiple emulators as well.  I kept getting blank screens.
youki
    • Atomic Front End
« Reply #7 on: June 29, 2005, 03:00:21 pm »
There is simple tutorial in the documentation provided with the distribution.
For a simple configuration you just have to say where is your emulator and where are your roms.  And that's all.
swindus
  • Last login:July 28, 2021, 05:52:50 am
    • MaLa - M.A.M.E. Launcher
« Reply #8 on: June 30, 2005, 03:34:55 am »
Later,
dabone
MaLa also supports all resolutions of the arcade vga, just use fixed size layouts and you are done.
loadman
  • Moderator
    • MaLa
« Reply #9 on: August 05, 2005, 08:43:11 pm »
The German on install has also been removed
