Author Topic: beginner controller questions  (Read 1654 times)
ewwfq
  • Newbie
  • Last login:June 25, 2005, 02:11:14 am
« on: June 24, 2005, 01:17:20 am »
Please answer this as I tried several other forums winth no success.
I have a PC with MAME32 installed on it and some Street Fighter games and I have a tough time performing special moves or supermoves with the keyboard- sometimes they work, sometimes they don't. I thought to switch to something else than the keyboard and was wondering what is the best type of controller (gamepad/ joystick/ wheel etc), the name of that controller (Company etc.) and with compatibility for MAME32. I need it for beat'em ups only and it has to have 6+ buttons.
Also it would be great to know what can I do to fix the keyboard's problem so I won't have to buy anything. I tried many keyboards and none worked perfectly.
markb
  • Last login:April 30, 2011, 06:41:02 am
  • The One and Only.
Re: beginner controller questions
« Reply #1 on: June 24, 2005, 08:50:01 am »
Are you keyboards USB or PS2? i'm fairly sure that on certain USB keyboards there is a limit on on 6 keys at a time being pressed.
Also my personal preference for controllers is a PS2 pad with a USB convertor box as i still find this to be the most comforatable controller on the market.
ahmer
  • Last login:March 16, 2014, 02:40:21 pm
  • Do as you like.
    • IC Markets Rebates and Discount
« Reply #2 on: June 24, 2005, 08:21:37 pm »
No any one here tell you the solution of your problem. :-\
I don't know while you are directly playing by using your keyboard or
making an arcade style controllers?but i think you are confuse here.
keyboards have limited data transfer,so they often jam when pressing more than 4 keys at a time.
it is very difficult to figure out more than 10 buttons press at once.
If you are playing streat fighter which is a 6 button game so
it will typically configure only for  player 1.
If you want to play in 1 player Vs 2 player by using a single keyboard
then you will be disappoint.Both the players can't apply special moves or combos due to keyboard hanging problem.
follow the link below and download this utility to understand
keyboard keys setup.(check the maximum no of keys can be pressed)
http://arcadecontrols.com/files/Utilities/keyscan09.zip
If you are making an arcade style joystick,the easiest and the cheapest way is just buy a (lowest price) Usb game pad and make
joystick.Usually there are many playstation pads layouts type usb PC game pads available so it should be 2 axis and 6/10 buttons joystick.
Original Playstation game pads with USB convertors can also be use
directly and could also be hack same as Usb game pads.
« Last Edit: June 24, 2005, 08:24:13 pm by ahmer »
Navmaxlp
  • Last login:November 08, 2014, 02:40:57 pm
« Reply #3 on: June 25, 2005, 07:23:39 am »
I've used a Hotrod SE before and was very happy. Nice thing about that is if you want to throw it in a cab you can nix the case and just use the joys, buttons and circuit board. Mame32 has direct support for the controler. All you have to do is go to controls, scroll down and Hotrod SE is right there. Should work from the get go. Hotrod has seven buttons per player so you are covered there. Also it's relatively inexpensive. I want to say it's right around $100.00
« Last Edit: June 25, 2005, 07:26:32 am by Navmaxlp »
