Author Topic: Want to use Power Strip - which refresh rate do i need for arcade monitor?  (Read 1720 times)
eggedd2k
  • Last login:February 14, 2006, 09:38:56 am
just downloaded power strip. can anyone tell me what settings i need to adjust in order for mame to display correctly on my arcade monitor??
cheers ;D
Smog
  • Last login:April 30, 2007, 06:50:51 am
  • .357
    • How to make a cheap GunCon2 work on your PC
there are predefined settings already in powerstrip. There must be a "640x480i (Arcade)" that is the last from the list.
GunCon2PC Driver on http://guncon2pc.no-ip.org/
eggedd2k
for some reason the custon settings section where the arcade setting you mentioned must be is greyed out and not available.
AmericanDemon
  • Last login:September 22, 2019, 11:08:03 pm
  • Still an AmericanDemon
Ah did you pay for it yet or on trial?
Smog
  • .357
Your video board is not supported. Try to download a newer version of PS
AlanS17
    • AlanS17
It also may mean that Powerstrip recognizes that the video card can't handle those resolutions and refresh rates.
