Author Topic: What voltages do you get at GND points on a jamma connector?  (Read 1279 times)
eggedd2k
  • Last login:February 14, 2006, 09:38:56 am
this might seem like a daft question but what (if any) voltages do you get at the Ground connection on a jamma connector?  Obviously the connector has a point for 5v and 12v but i was wondering if it mattered which ground connector you should use for testing voltages etc
ShinAce
  • Last login:January 16, 2007, 07:38:14 pm
  • Building the unbuildable since 2001
Re: What voltages do you get at GND points on a jamma connector?
« Reply #1 on: June 22, 2005, 08:13:38 am »
The very definition of ground is a reference voltage, or 0 volts.
An ounce of image is worth a pound of performance.
eggedd2k
« Reply #2 on: June 22, 2005, 08:17:28 am »
thanks mate. i feel like i've asked a daft question
