Author Topic: MAME athlon build, problems with hi. ?  (Read 1267 times)
tore-
  • Last login:June 11, 2014, 06:18:33 am
« on: June 20, 2005, 07:09:37 am »
I've used the athlon custom build of mame in my cab., just recently i discovered that none of my highscores in any games are saved upon exit.
Does anyone know if there are some issues with the builds over at redump.emubase.de?
I only got to check if the hi folder was read only, it wasnt, will try to use the original build some of theese days, but work is killing me.
Tiger-Heli
    • Tiger-Heli
Re: MAME athlon build, problems with hi. ?
« Reply #1 on: June 20, 2005, 08:43:06 am »
Silly question, but did you put the hiscore.dat file (http://www.mameworld.net/highscore/) in your MAME directory?
tore-
« Reply #2 on: June 20, 2005, 08:45:46 am »
.... Had to forget the hiscore file...
I did a reinstall of windows, only saving the rom files and hi folder, no wonder the thing didnt saved hiscores....
Thanks...
