Author Topic: Using Video Card and Monitor Setup  (Read 1444 times)
toolaa
  • Last login:April 04, 2024, 02:03:09 pm
  • Work In Progress...
    • Moon Patrol Project
« on: June 19, 2005, 11:29:57 pm »
This is my first post to this fine group.
Super Sprint - In Progress ($150)
Moon Patrol MAME - Completed ($670)
Tic-Tac-Strike Puck Bowler - Restored ($1200)
First Time Visitors Say "Holy Cow!"
. . . . . .Priceless
markb
  • Last login:April 30, 2011, 06:41:02 am
  • The One and Only.
Re: Using Video Card and Monitor Setup
« Reply #1 on: June 20, 2005, 06:43:17 pm »
I'm not sure if this will help (because i'm not exactly sure of your problem!) but here is a link to some alternative ATI drivers:-
http://www.omegadrivers.net/
Use the links on the homepage to navigate to the alternative driver, but be aware that these are unapproved drivers however I have used them on my 9800pro for 3 months with no effect.
Also here is a utility called multires which may be of use:-
http://www.entechtaiwan.net/util/multires.shtm
Between them they have more tools than the catalyst driver so they may give you what you require.
toolaa
« Reply #2 on: June 22, 2005, 12:35:11 am »
Thanks for the direction.  I researched both and this lead me to other utilities.  It looks like UltraMon might do the trick.
http://www.realtimesoft.com/ultramon/
My problem is that I always want to get GameEX to always open on the secondary monitor which is the Component Out.  Then the GameEX front end is closed, the screen reverts back to the S-Video.    The built in ATI Hydravision software would not to it, nor would the default windows extended desktop features.
Thanks Agin for the help.
Next I am going to try to figure out how to trigger some output on my PC to power a relay switch to automatically switch my TV from Component to S-Video input, when I switch between desktops.
