Author Topic: ps/2 or usb?  (Read 1051 times)
joshbr7257
  • Last login:August 15, 2006, 10:12:28 pm
  • B.Y.O.B.!!!!!!!!!!!
ps/2 or usb?
« on: June 19, 2005, 01:12:30 am »
im going to buy the ipac2 and i want to know what the differences are between the 2?
WANT A FREE PSP? CLICK BELOW.
http://www.FreePSPs.com/?r=17776949
AlanS17
    • AlanS17
Re: ps/2 or usb?
« Reply #1 on: June 19, 2005, 02:08:36 am »
The connection options are pretty much just for preference. They work the same.
For instance, a Mac user wouldn't have a PS2 port.
joshbr7257
Re: ps/2 or usb?
« Reply #2 on: June 19, 2005, 02:28:57 am »
does it matter if you use dos mame? or mame32? or windows mame? what about front ends?
elvis
  • Last login:January 13, 2025, 08:48:40 am
  • penguin poker
    • StickFreaks
Re: ps/2 or usb?
« Reply #3 on: June 19, 2005, 03:11:47 am »
When you say "USB" do you mean a USB-gamepad chip, or a USB-keyboard chip?
Obviously the I-Pac(tm) is a keyboard encoder, but people here have a bad habit of referring to things under a generic banner.
If it's a keyboard encoder, USB or PS/2 doesn't matter.  Most systems will enable USB-PS/2 compatability within the motherboard's BIOS so that even DOS can take input from the encoder via USB.  Linux 2.4/2.6, MacOSX and Windows 2000/XP will all handle USB keyboards natively.
If it's a USB joystick/gamepad encoder, that's a different story.  DOS is out of the question here from the word go.  MacOSX, Linux 2.6 and Win2k/XP are all fine from an OS/Kernel and MAME point of view, but you're going to have to check up on your frontend of choice to make sure it allows mappings from USB-joystick device inputs to the frontend.  I know from personal experience that MAMEWah under Win2K/XP is fine, and so is AdvanceMenu under Win2K/XP and Linux 2.6.  Anything else you're going to have to check for yourself, or hope that someone who has used/written them is kind enough to spot this thread and answer.
Performance wise, it doesn't matter squat.  I know there have been massive fights in here between USB fans and PS/2 fans over whose encoder is 2ms faster than someone else's encoder, but at the end of the day it doesn't make any bloody difference to me playing on my 2-player cabs as to which I use, and I've tried various brands in various USB and PS/2 setups, and it all feels the same to me.
joshbr7257
Re: ps/2 or usb?
« Reply #4 on: June 19, 2005, 03:19:53 am »
ok the site wants to know first if i want a usb or ps/2 encoder, then second its giving me a cable? and wants to know:
it askes if i want a ps/2 cable or usb cable??? what do i choose?
http://www.ultimarc.com/JShopServer/product.php?xProd=3&xSec=2
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
Re: ps/2 or usb?
« Reply #5 on: June 19, 2005, 03:32:24 pm »
I used a hacked PS/2 keyboard and mouse for my CP and regret it. Now, all I can use to work on the computer is the only USB keyboard and mouse I have, rather than the many PS/2 ones I own.
Also, USB is much easier to hot swap.
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
joshbr7257
Re: ps/2 or usb?
« Reply #6 on: June 19, 2005, 08:42:57 pm »
but the I-PAC has a built in keyboard plug, so you can still use a keyboard
markrvp
  • NFL Expert
Re: ps/2 or usb?
« Reply #7 on: June 19, 2005, 08:46:02 pm »
Ultimarc suggests that if you are going to use a keyboard connected to the Ipac passthrough that you hook-up the Ipac via the PS2 cable.
So to answer your question, order the PS2 version with the PS2 cable.  Then plug it into the PS2 port on your PC.  You can always get the USB adapter cable later.
danny_galaga
  • Last login:December 01, 2025, 06:37:38 am
    • dans cocktail lounge
Re: ps/2 or usb?
« Reply #8 on: June 19, 2005, 08:54:10 pm »
yeah, the adapter is only about 5 bucks extra. the key board emulator is exactly the same, just you get the extra cable. and i've heard that its hard to get USB drivers for DOS (but i dont know this from experience, just what ive read on this forum). so if youre going for DOS, bear that in mind...
joshbr7257
Re: ps/2 or usb?
« Reply #9 on: June 19, 2005, 09:10:04 pm »
i think ill go ahead and get the ps/2 version with the ps/2 cable. thanks
