Author Topic: Joysicks: the 3rd dimension  (Read 1060 times)
computerror
  • Last login:June 19, 2005, 01:59:31 pm
« on: June 18, 2005, 05:14:39 am »
Hello,
I'm new to this forum, and my main reason for coming here, is the fact I'm gonna build a control-panel for a modern arts installation together with a friend of mine, here in Holland.
For this project, you'll be sitting inside a dark caravan with a screen + control-panel in front of you, and 2 good speakers to your left and right ears. With the control panel you can manipulate the sound; switching loops ON-OFF (push-buttons/toggle-switches) and control ambientic sound FX (knobs, sliders and, most important, 2 joysticks). The control-panel shall also make the visuals (think (old) industrial machines ;D) change, in 'harmony' with the sound FX / rythmic loops.
So, I was wondering, maybe there's is someone around on this forum knowing very much about joysticks, and is able to tell me the following:
"Are there any 3-axis joysticks, where the Z-axis responds to the degree of vertical movement of the shaft of the joystick, rather than 'twisting the head' of the shaft, as seen in a lot of industrial 3-axis joysticks?"
Thanx guys!
gl.tter
  • Last login:October 10, 2009, 04:53:44 pm
Re: Joysicks: the 3rd dimension
« Reply #1 on: June 18, 2005, 02:10:54 pm »
Hey there, interesting sounding project.
I've dabbled in a few alternative PC controllers over the years.
author of the Quake2 and Half Life Act Labs lightgun conversions:
gl.tter
« Reply #2 on: June 18, 2005, 03:55:06 pm »
Couldn't remember or find anything on the movable stick - anybody else remember it?  You could sorta slide it around.
This is the SpaceOrb.
computerror
« Reply #3 on: June 19, 2005, 01:54:27 pm »
Thanx, but we'll need a sturdier controller. I'll just keep on searching the net :)
gl.tter
« Reply #4 on: June 19, 2005, 01:58:12 pm »
Just had an idea - you could use a Wacom digitizing tablet.
« Last Edit: June 19, 2005, 02:39:00 pm by gl.tter »
