Author Topic: Okay, can we get a freakin' GunCon2 FAQ going?  (Read 1716 times)
quarterback
« on: June 17, 2005, 12:45:31 pm »
I've been keeping up with ALL the GC2 threads, but I freely admit I don't understand every bit of the discussion
-- Chad Tower
IntruderAlert
  • Last login:May 02, 2007, 09:10:59 am
  • Chicken.. Fight Like A Robot
    • Intruder Alert
Re: Okay, can we get a freakin' GunCon2 FAQ going?
« Reply #1 on: June 17, 2005, 12:49:14 pm »
Here's Smog's forum if you want to discuss any of this with him:
http://www.freeforumzone.com/viewForum.aspx?f=66424
vibez
  • Last login:February 09, 2011, 08:33:20 am
« Reply #2 on: June 17, 2005, 02:55:30 pm »
regarding question 4:
 I'm not sure on smogs opinion, but I think the driver ( or more arguably - the connection methods) are far from perfect for the masses. although I will admit it works fine for me & smog. That is where we are stuck. Smog cannot fix the problems that most people are having as he cannot replicate any bugs, thus cannot fix them
Everything is still in development stages. The driver has nearly reached maturity, it just need a few things adding (built in flash). which I think zero point & smog are working on???
Hopefully smog will open source the driver soon. Fingers crossed
BTW Intruder:
Andy says that the jpac connection method works flawless for him. Maybe its time to add it to your page?
« Last Edit: June 17, 2005, 02:58:05 pm by vibez »
lettuce
  • Make It So!
« Reply #3 on: July 26, 2005, 01:29:36 pm »
So how do you connect Th G-Con2 gun up to a PC using J-PAC, ArcadeVGA card, and a Arcade Monitor? Im guessing the USB cable from the G-Con2 plugs into athe USB on the PC, but what about the Yellow video cable thats surpposed to plug into the TV, where does that go inisde the cab?
